How to build a wire guide?
  • How to build a wire guide?
    It would help me very much if someone could tell me what the two spacer parts are called. How far apart do I space them? I know it has to be less then the width of the bobbin, but by how much? And is there a method for lining them up other than trial and error? Thank you.
    -Rob
    Most, just use 2 set screw collars on a smooth rod.
    http://www.mcmaster.com/#shaft-collars/=l92pg6
    I have a homemade wire guide that is bracket that I put a shoulder bolt through.
    I put a steel tubular sleeve on the sholder bolt.
    I run the wire under the tubular sleeve, (wire roller).
    I have one of these roller sleeves cut for each width of pickup I make.
    The roller has preset edge stops, on the roller.
    You want the wire guide just a bit narrower than the bobbin.
    The width is a trial and error thing.
    T
