I bought an older Vox Tonelab ST. It works OK, but I guess its output level is low. If I choose some amp simulation and set both gain, volume, EQ and level pots to max there's only about 0.5V RMS on output and so for "normal" bank settings only about 0.1-0.3V RMS. It isnt sufficient to drive transistor or valve guitar power amp with typically about 0.7- 1.5V RMS sensitivity for full power output. I tried to change the valve but nothing improved.
I would like to know if this effect output level is normal or my unit has some problem to repair it.
