I just find it odd nobody can figure out a way to measure the differences between capacitors in a circuit. Either changing capacitors changes the frequency response or adds distortion. Can't think of too many other effects.
Sound differences between cap brands? Test results?
Good point!
There is such a thing called "Scientific Method".
(ie: the scientific method attempts to minimize the influence of the scientist's bias on the outcome of an experiment.)
I cannot imagine going for a grant to study this phenomenon with phrases such as: "I like, sounds better".
If a difference can be heard it can be said that:
(1) the difference should be reproducible by anyone with the same setup.
(2) the facts must be backed up by some type of data.
I can definitely hear difference between caps...
Crap caps start to sound really bad when they turn to the dark side. The life span tend to be longer if you get a good cap, not tautology unfortunately. And the illusive paper in oil caps seem to be immortals. I have some friends claiming to have revive some old amplifiers with snake oil caps. I see, or better yet, hear two things. Old road worn caps have been replaced with new fresh caps. And not to be forgotten, they really believe they hear the brand, or type of cap. I think both reasons are to be taken seriously.In this forum everyone is entitled to my opinion.
I think the sound of caps are not as big a problem then as how the listener listens to sound. And if your making music, all created sounds are valid if constructed with a tasteful ear.
I have extremely revealing stereo speakers that have me hearing parts of songs that I've grown up listening to and never noticed before. If I listened to this music through two guitar amps, those parts would have gone unnoticed. My stereo amplifier has all film/foil caps, and if I changed them all out for paper/wax, or ceramic, or paper/oil etc, I probably wouldn't be able to tell the difference in any of them. But I bet someone else could. And that they could, really doesn't matter to me.Now Trending: China has found a way to turn stupidity into money!
The trouble with recorded samples, as input or reference, is that they are another source of signal distortion. So you would then need to determine the affect the mic, media and interface amps have that might mask otherwise audible differences.
Just playing devils advocate here.
I've done some tests and I really don't think it's possible to discearn between film caps of different brand or construction when only one cap is swapped. I once built two amps that were identical with the exception of using Mallory 150's in one and Vishay 715P's in the other. I could hear a difference between the two amps. BUT... If I had built both amps with the same type of capacitor I probably still would have heard a difference. All the resistors, tubes and capacitors have value tolerance. No two amps are the same. Bias points will be a little different as will pass frequencies, balance of circuits like phase inversters and attenuations from voltage dividers, etc. So it's hard, even with the two amp model, for me to commit to a difference in film caps. Anyway, the difference was so small that wouldn't merit stressing over one type or the other.
A bigger difference in cap construction comes from derate conditions. Polypropylene caps are more temperature stable than other types. So if you want your amp to sound the same on set three as it did on set one, use polypropylene."Take two placebos, works twice as well." Enzo
I got around to hearing the sound samples from Metroamp. If you listen to the recordings in sequence it is hard to conclusively say if there is a difference or not between the caps. What I did was mark the locations on the file with the same passage and clicked between the same sections as they played. I must have bad ears as I did not hear any difference. I would say that if one piece of one recording were spliced into one of the other cap's recording I would not notice where the splice took place.
Originally posted by Chuck H View PostThe trouble with recorded samples, as input or reference, is that they are another source of signal distortion. So you would then need to determine the affect the mic, media and interface amps have that might mask otherwise audible differences.
So Daz, how did you do on identifying the different caps in those sound clips from the Metro Amps forum? You should have heard those "lead pipe upside the head" differences.
Edit: Doh! I just listened to the track and he ruins the test by telling you which caps are which. I'm going to edit the voiceover out and get back to you."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
Originally posted by Steve Conner View PostEdit: Doh! I just listened to the track and he ruins the test by telling you which caps are which.Aleksander Niemand
Listening to the Metroamps example #1 is the best to hear a difference in my opinion. I hear the mallory caps in the first example and it has more bite with a more airy sound. The other examples in sound bite #1 sound a bit thicker in the low mids as they go through each example. I hear just a tiny difference of low mids at times in each these other examples. The mallory caps to me stand out as a totally different sounding in this example.
When in example #2 of a lead tone pushed loud it is hard to hear any difference at all. The leads all sound almost the same to me with really no distinct difference. To me when the amp is pushed it makes almost no difference at all in tone.
The more you listen to the clips the less objective your ears become and the only one I would be able to pick out of all the clips is the first one w/ mallory caps.
There is a slight difference with NOS mustard caps and another slight difference w/ NOS mustard caps w/ NOS preamp tubes at the end of example #1. That is all very subjective and I don't really feel that I care so much as listen over and over again. Actually the more I listened made me just want to find the one that is most cost effective and go with that signal cap. To me I can use EQ and other vices to make my guitar sound the way I want it to sound.When the going gets weird... The weird turn pro!
Originally posted by Jazz P Bass View PostI don't have the time or inclination but could someone run the clips through Audacity or a similar program?
Then you can 'see' what you are 'hearing'.
Th thing about all this that IMO is important is this....subtle things, especially when additive via several subtle but good changes, can make what amounts to a huge improvement in your amp in how well it fits in a mix. And when it does that also tends to make it better solo too. They can sound subtle when you listen for the differences, but when you are just playing and not listening for those things, otherwise subtle things can show up by just seeming that the amp doesn't quite feel or sound the way it should and you struggle to fit in the mix and your playing goes to cr@p. You may not even know what the difference is, and thats the crux of this thread IMO......just because you can't tell doesn't mean theres not a subtle difference, and that subtle difference can result in no so subtle changes in the way the amp works with you.
Originally posted by Steve Conner View PostSo Daz, how did you do on identifying the different caps in those sound clips from the Metro Amps forum? You should have heard those "lead pipe upside the head" differences.
For me, this test really confirms my suspicions and I'll continue to use whatever film capacitors I can get my hands on.
