Vendor for Eyelet Fiberboard Needed - Mine is out of stock
  • Vendor for Eyelet Fiberboard Needed - Mine is out of stock
    Doing a vintage clone build that requires a filter cap board (for 6 large caps, not 5) that no one (I've found) stocks so I need the materials to build one.
    Does anyone have a source for the eyelet type fiberboard? MojoTony is out of stock, haven't seen it on fleabay either.
    McMaster-Carr has everything it seems...
    Now Trending: China has found a way to turn stupidity into money!
      Except fiberboard.... try WeberVST and see if they will sell you some blank board stock.
      Bruce
      Mission Amps
      Denver, CO. 80022
      www.missionamps.com
      303-955-2412
        Good ideas, thanks guys.
          Just have to know what to look for.....
          Electrical-Grade Garolite (G-9)
            Is Garolite G-9 identical to vulcanized fiberboard?
              Oh, you wanted that stuff that old Fender's used.... here it is McMaster-Carr
              They don't list .060", but you could just use two .030" pieces sandwiched. The fiberglass board(G-9) is much better, electrically and physically, and it's what I'd use for a custom build. Fender went with the cheapest stuff to cut costs.
                I also prefer the G-9 Garolite to the fiberboard. You can order a 4-ft x 3-in. section shipped for about what you would pay for one fiberboard and have plenty left over for whatever you like. More reading here in this old thread.
                My Builds:
                5E3 Deluxe Build
                5F1 Champ Build
                6G15 Reverb Unit Build
