Can bias be that low?
  • Can bias be that low?
    Hi guys,
    I just bought a Tweed Pro kind of amp. It sounds great but stays extremly clean and the distortion is a little bit more "ratty" than I would like. I listened to that amp in a store and the breakup was more pleasent and way earlier.
    So I tought I might just measure the bias cause I know this kind of sound from my Deluxe Reverb. Plate Voltage is 450V. But the bias I measured is just 8ma with 6L6. This seems really strange to me. I measured like I do every time with the resistor method. When turning up the bias pot I got a maximum of about 18mA. The amp has fixed bias.
    Regards Jens
    About 8 watts of dissipation, there is a problem.What voltage can give the bias pot (measure on the grid pin) ?
      The strange thing is the amp sounds really really loud and not really broken.
        I removed the tube an measreud the grid pin. -42V.
          Sorry guys. Not my day today. I measured mA not mV. It shows 32mV I turned the bias pot to 40mV which should give me 40mA. So everything is OK.
