How To Build A Magnet Charger (Guide)
Is anyone here educated enough to tell me how this can be built as a plug-in? Even if it requires more parts...it would be nice to not have to worry about the battery and whether or not it is charged up. How strong (amps rating) of a power supply would one need?
-Rob
Electric Davyboy built one I think.
Robert, think about it, a lead acid car battery can put out 700-800 "Cold Cranking Amps" as the ads say. You can't get that much juice out of a wall outlet without some form of storage. You can either go with capacitor banks or with a really big, iron cored transformer. WHat's so hard about using a trickle charger and keeping the thing plugged in?
-Rob
Walker High Power Magnetizer Magnet Charger | eBay
Dont think I have much room for that, hahahahaha....
-Rob
Electromagnets are all about amp-turns. This thing runs off 12V at 40A, you can get exactly the same result with 120V, 4A. Just use 10x as many turns, of magnet wire with 1/10 the cross-sectional area.
Obviously you have to use DC. You can plug it into the wall using a bridge rectifier. Put the switch on the AC side of the rectifier, and when you turn it off the rectifier will act as a flywheel diode to discharge the magnetic energy safely. Put the switch on the DC side if you want it to die instantly in a huge flaming arc.
Large neo magnets may be a better solution nowadays if you don't mind handling them."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
I built Gingery's magnetizer myself a few years ago, but IMO it didn't really have quite enough oompf to get magnets completely charged even at 10A measured at 120VAC input. I was thinking about some kind of power amp for it to raise the energy going to the coils to do a better job. I used modern 150C rated coil wire, and a cap bank made of 500VDC caps (mil surplus) too.
kenLast edited by ken; 03-05-2013, 04:53 AM.
