What is this called and where do I buy one???
Tags: None
Originally posted by rhgwynn View Post[ATTACH=CONFIG]22098[/ATTACH]
I know I can make one with two magnets and a clamp. But I would like to eventually have one of these.
-Robert
Here is a cheap one from Sears: Craftsman Magnetizer, Magnet, and Demagnetizer - Tools - Hand Tools - Screwdrivers
(Primitive but does the same job)
However, there are many different shapes and sizes of this tool.
The one you have is made to have interchangeable magnets, gap sizes...
It is used to magnetize demagnetize tools, screwdrivers, pliers, and is popular among watchmakers and other crafts persons....
Originally posted by David King View PostNeedless to say it's not powerful enough to charge alnico rods or bars to full capacity. You need some good sized neodymium magnets for that.
-Rob
1. it looks non adjustable.
2. Like DK said not big enough for Bar Magnets.
Long bar magnets are harder to get a consistent charge, than short rod magnets.
long neos in a vise is ideal for Humbucker bar magnets.
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Just do this:
It's adjustable, and the metal vice completes the circuit.
I usually use two larger magnets on each side.
Originally posted by SpareRibs View PostHello David Schwab,
I want to build the magnet charger you have shown. I have all the parts could you just explain the orientation of the magnets or will it be the same no matter because the circuit is complete?
Thank You
-Rob
Originally posted by rhgwynn View PostOne side of the clamp face north inwards and the same with south on the other side of the clamp.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Just be really careful with multiple neos. Wear gloves and eye protection. Be really methodical and don't let the magnets slam into each other as they have a bad habit of shattering explosively. They are nickel plated to look like metal but they are very brittle inside, more like fired ceramic. The shards are very sharp.
I've seen even small ones jump huge distances and the results are often not very pretty. A safer way to deal with them is to stick one on a thin piece of sheet metal and the stick that to the vise jaw. You can slide the sheet metal out afterwards.
I had a bunch of bookmarks where to buy NEOs, after my last Laptop died, they are gone.
Where do you guys buy NEOs, I forgot, and lost the bookmarks?
Originally posted by big_teee View PostI had a bunch of bookmarks where to buy NEOs, after my last Laptop died, they are gone.
T
K&J Magnetics - Strong Neodymium Magnets, Rare Earth MagnetsTake Care,
Jim. . .
VA3DEF
____________________________________________________
In the immortal words of Dr. Johnny Fever, “When everyone is out to get you, paranoid is just good thinking.”
Originally posted by SpareRibs View PostHello,
Would it be possible to change the orientation on ceramic magnets from top being north, bottom
south to the sides being north and south like humbucker magnets using the neo magnet setup ?It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
