Cable for LaMar Mastervolume?
  • Cable for LaMar Mastervolume?
    Lar/Mar PPI-MV - MetroAmp Wiki
    I would like to do this mod. I have shielded cable but just with one conductor. I have no idea where to get 2 conductor shielded cable that is rated for 300V.
    Should I try to get 2 conductor cable or should use two 1 conductor shielded cables instead?
    Thanks.
    Thanks.
    I did the mod and made my own cable.
    I took some braided cable and threaded 2 wires in the braid.
    The cable is short so this is not that hard to do.
    When finished, I put a piece of heat shrink over the braid and shrunk it down.
    Looks and works great!
    T
      ahh this should work
      http://www.thomann.de/gb/sommer_cable_primus_bl.htm
        I wouldn't order something just to get a few inches of cable. Just run two pieces of single conductor.
          For future reference (or for your LarMar, in case you want to order more wire), I started a thread on this very question a while ago:
          http://music-electronics-forum.com/t31748/
            You don't need shielded cable.
              shielded wire won't hurt, and they show it on the mod.
