Results 1 to 3 of 3
Thread: Mercury Rectifier Tubes
    Dec 2007
    967
    Received: 20/0
    Given: 2/0
    13
    I've got a bunch of old mercury rectifier tubes and I was thinking about sticking them in some of my amps. On the net, I read about all sorts of problems and dangers with using these tubes, like mercury poisoning and creating a toxic home that would have to be destroyed should a tube envelope break while powered up. They also talk about noisy operation and a very controlled preheating of the tube filaments to make sure the mercury doesn't create a short. The claim is that you have to preheat the tube for half an hour anytime the tube is moved or transported to put the mercury back in the right place. I also checked the old Fender schematics for the 5F8 and 5F6 amps, and find that Fender took no special precautions when using the #83 tubes. They even operated them upside down, which should be a no-no according to the literature. There is no difference in the Fender circuits when they swapped over to a GZ34 rectifier. So, I'm looking for a little practical advice here. Did Fender have all sorts of reliability problems with the 83 tube in their amps, or are all the concerns with this tube overblown? I found some tube socket adapters that allow an easy swap betweeen the 4-pin tubes and octals at Angela Instruments, so I'll be ready to experiment soon.
    http://frank.pocnet.net/sheets/093/8/83.pdf
    http://frank.pocnet.net/sheets/155/8/83.pdf
    Senior Member km6xz's Avatar
    Dec 2010
    St Petersburg Russia
    1,842
    Received: 22/0
    12
    Being an old timer, I used Mercury Vapor Rectifiers a lot in the 50s and 60s. They have some electrical advantages, mostly their low ionization potential, meaning they had lower voltage drop than regular rectifier tubes. Another advantage is a reasonably high level of self regulation so supplies built with them would have less sag with higher current flow. So this might be audible as a tighter sound. They produced higher power out in the same circuit because of lower drop across the tube. But they also needed a bleeder resistor for constant minimum load because they were intended for use with choke input filters.
    The larger ones, like the 866a last a long time, but a pair is needed for full wave rectifiers. They are not good for portable gear because they do not take well to extremes of ambient temperatures and might not start at all if the bulb is too cold. If ambient it too hot, they can arc. They need a warm up period with no plate voltage applied. We always used time delay relays if used by other people but usually dispensed with that if for personal use by someone who was familiar with their care and feeding.
    If used in a guitar amp, their blue glow that was modulated by the current flow was really cool to watch. I never used them in an amp but in lots of higher power ham radio transmitters using AM or CW so the flashing of the rectifiers was a very nice visual effect in a dim room. They can also make noise, audible noise that was directly related to the current draw.
    Later, high vacuum rectifiers took their place, like the 3B28, which could be used without the vaporizing waiting period, and over a wider range of temperatures. The sad part was the more modern 3B28 did not glow but were quiet and could be used in any orientation.
    They ARE a hazard if broken. We did not take special precautions back in the day but now everyone is concerned mercury poisoning.
    Your home owners insurance probably has a prohibition or exclusion that holds them not responsible for you getting your home declared a hazard site and you losing all your investment if anyone finds out that one broke in your house.
    Dec 2007
    967
    Received: 20/0
    Given: 2/0
    13
    Thanks KM for the good info. I wonder how many of us out there have dropped thermometers on the floor and scattered the mercury about. I know I did years ago. I also remember the giant jar of mercury in science class used to make manometers and help to understand atmospheric pressure. I know that school is still there today.....
  1. Rectifier tubes and sag
    By daz in forum Theory & Design
    Last Post: 06-04-2016, 01:06 AM
  2. Blowing rectifier tubes
    By J Hog in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-14-2009, 03:12 PM
  3. Single Rectifier without power tubes
    By PaulSM in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-28-2009, 03:07 AM
  4. Pulling tubes Triple rectifier???
    By TREC in forum Mods & Tweaks
    Last Post: 05-11-2009, 04:46 AM
  5. Dual Rectifier Tubes
    By Fletcher Munson in forum Theory & Design
    Last Post: 11-02-2008, 01:18 AM
