of course an 8 string would read higher than a 6 because the coils are longer, funny thing they did with the 8 string- use a 6 string bobbin, put an extra pole on each end and wind the coil right out into the air unsupported. Rickenbackers had some of the crappiest made parts and backwards methods of any manufacturer out there
Horse Shoe Pickup
Originally posted by jason lollar View Postof course an 8 string would read higher than a 6 bsing 6 string partsecause the coils are longer, funny thing they did with the 8 string- use a 6 string bobbin, put an extra pole on each end and wind the coil right out into the air unsupported. Rickenbackers had some of the crappiest made parts and backwards methods of any manufacturer out there
www.sonnywalton.com
Originally posted by SonnyW View Postand they soldered the start wire to a sawed off brass screw.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by jason lollar View Postof course an 8 string would read higher than a 6 because the coils are longer, funny thing they did with the 8 string- use a 6 string bobbin, put an extra pole on each end and wind the coil right out into the air unsupported. Rickenbackers had some of the crappiest made parts and backwards methods of any manufacturer out there
Jeff
Originally posted by David Schwab View PostAnd they still do!
Greg
Originally posted by David Schwab View PostHere's the bottom with the rubber magnet removed.
Pickup prototype checklist: [x] FR4 [x] Cu AWG 42 [x] Neo magnets [x] Willpower [ ] Time - Winding suspended due to exams.
Originally posted by David SchwabThen you have neos... which is a fuzzy bunny wrapped in barbed wire.
Originally posted by jason lollar View Postno one knows much about the older pickups at Rickenbacker that I have ever talked to- they don't have any reason to know though.
