kt66 datasheet specs
  • kt66 datasheet specs
    ive been searching the web for kt66 data sheets, it seems there are only 3 with the info im looking for, genelex, osram, and gec.
    jj's data sheet provides minimal info.
    i am trying to find given specs for this tube at roughly a 450 b+ voltage for a fixed bias ab1 push/pull amp.
    i am having trouble understanding the neg grid voltage, plate to plate resistance and power output wattage specs listed as these data sheets only show the specs for auto-bias in my b+ range, they only show for fixed bias at the max 510v b+. should i be concerned with the difference in specs between "auto-bias" and "fixed-bias" as listed?
    as i understand it the specs are not the same for auto-bias vs fixed-bias, i want to make sure im getting the correct info!
    thx.
