Line 6 Spider II - noise and channel switching issue
  • Line 6 Spider II - noise and channel switching issue
    I have a Spider II that I bought from a friend.
    The issue I'm having is that while the amp is on it makes popping noises, will increase volume briefly and then come back down to normal volume.
    This happens whether a guitar is plugged in or not.
    It will also switch channels on occasion while I'm playing it.
    I took the head apart to look for loose wires or possible cold solder joints or bad grounding but nothing was obvious.
    Please provide suggestions.
    thanks
    I had that problem and it ended up being the ripple filter electrolytics.
