Results 1 to 10 of 10
Thread: Weber Java Kit
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    11,538
    Received: 942/32
    Given: 913/14
    22
    Weber Java Kit
    Has anyone built a Weber Java Kit.
    It appears to be a Trainwreck Express on Steroids.
    Weber Original Design Kits
    If you look at their schematic, and compare it to the Expresses.
    https://taweber.powweb.com/store/java_schem.jpg
    http://www.blueguitar.org/new/schem/...k/wreckxpr.pdf
    I'm wondering why they don't use a choke.
    I notice none of the TWs use Chokes.
    Looks like hum and noise would be an issue?
    Any comments on both the Trainwreck Express and the Java Appreciated!
    Thanks,
    "You can't promote principled anti-corruption action without pissing off corrupt people!" Diplomat George Kent
    Near Dallas Texas
    3,554
    Received: 243/0
    Given: 123/1
    18
    The TW Express is tightly tuned for B+ sag induced compression. There is a story that Ken could hear the difference between 9.1K and 10K resistors in the decoupling string while listening over the phone. I'd like to get ahold of one to measure the gain and compression.
    Jun 2010
    Mid-South USA
    11,538
    Received: 942/32
    Given: 913/14
    22
    Quote Originally Posted by loudthud View Post
    So what happens if you use a Choke?
    Will it drastically change the tone?
    I guess I could try it both ways if and when I build it?
    T
    Senior Hollow State Tech Bruce / Mission Amps's Avatar
    Denver, Colorado
    3,045
    Received: 8/0
    17
    Unless you have NOS preamp tubes, the correct NOS EL34s, the right carbon impregnated black dye wire and correct zinc oxide dye wire... both of which will need to be glued down to the sweet spot on the chassis, plus those old TMI trannys.... you aren't going to get a Trainwreck.
    Regardless, stay away from cheap Chinese parts and Chinese transformers and you'll get a very good sounding handmade amp.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
    Chicago, USA
    4,909
    Received: 77/0
    18
    The Java kit uses CF to drive the tonestack. I don't remember seeing an Express schematic that did that.
    Jun 2010
    Mid-South USA
    11,538
    Received: 942/32
    Given: 913/14
    22
    Quote Originally Posted by bob p View Post
    If you look the CF is Optional.
    It can be built with or without it.
    I was actually shooting for a 2204, but Weber didn't make one.
    The Java looked like about the closest thing.
    Looked like a lot of parts there that can be made into something.
    The Guy I was going to build for doesn't have a lot of Jack.
    T
    Jun 2010
    Mid-South USA
    11,538
    Received: 942/32
    Given: 913/14
    22
    After further searching through different schematics, the Java is just a variation of the 6G6 Bassman.
    I think I will make my own variation of the 6G6 and put it in a JTM45 Cab, with a choke!
    http://www.el34world.com/charts/Sche...SSMAN_6G6A.pdf
    Chicago, USA
    4,909
    Received: 77/0
    18
    I think that part of what you're noticing is that the basic topology of some of these gainy boutique amps looks like a lot like a Princeton Reverb with a jumper in place of the reverb mix resistor. some values get tweaked along the way to voice the amp.
    Dec 2009
    1,178
    Received: 4/0
    Given: 1/1
    12
    I ordered some stuff way back, no kit though. I seem to remember weber being cheaper then most vendors, but the stuff I got wasn't, well lets to it, as robust as I had hope.
    Edit, you sure you want an amplifier without reverb?
    Jun 2010
    Mid-South USA
    11,538
    Received: 942/32
    Given: 913/14
    22
    Quote Originally Posted by überfuzz View Post
    Going to build another amp with gain, without reverb.
    Will sell my friend one of the two. I will have after I build this one.
    He wants to buy my 2204 clone, but I will need something to replace it.
    He likes my 2204, He Says it Has Balls!
    He has a bunch of combo amps with reverb but doesn't ever use it.
    He does use some pedals though.
    I will probably order some stuff from weber, and some stuff from mojo.
    I have an account with mojo, but some of their stuff still high IMO at a discount.
    TubeDepot has some pretty good prices on some stuff, like loose resistors.
    T
  1. Weber 6H50 Kit
    By big_teee in forum Kit Amps
    Last Post: 04-16-2013, 01:19 AM
  2. Weber 6A20 kit blowing fuses
    By rstreber in forum Kit Amps
    Last Post: 03-18-2010, 02:40 AM
  3. Weber vs Metropoulos Plexi Kit?
    By Amptone1 in forum Kit Amps
    Last Post: 02-20-2008, 03:26 AM
  4. Too high B+ in 5F6A Weber Kit with M-M Iron
    By Mark Black in forum Debugging Your Build
    Last Post: 03-07-2007, 01:14 PM
  5. weber java issues...please help
    By Cbookman in forum Debugging Your Build
    Last Post: 02-21-2007, 02:55 PM
