Vox Night Train 50
  • Vox Night Train 50
    I emailed Vox, no reply yet.
    Has anyone got the NT50H schematic?
    Doug
    Vox Night Train 50 Schematic
    Attached.
      Thanks Jazz P , but the NT50H is different: 4 12AX7, 2 EL34, 4 relays.
      I have an intermittent connection, could be a relay or a solder
      connection, when I flex the PC board. A schematic would make it easy.
      Doug
        Doug
        Doug, have you received the schematics from Vox? Mine broke down in shipping, and could not be fixed without schematics. I would be really thankfull for your help!
          It turned out to be bad pots. Several of them had loose terminals. I had to de-solder and crimp them.
          PITA! On an almost new amp! Other than that It looks like a well built amp.
          Doug
          http://music-electronics-forum.com/a...1&d=1377647973
            it turned out to be bad pots. Several of them had loose terminals. I had to de-solder and crimp them.
            Pita! On an almost new amp! Other than that it looks like a well built amp.
            Doug
            thank you doug! Soooooo much!
