Traynor YCV40 Blown DC Filament Circuit
That is AC, not DC. The 100R resistors are the ground reference. They can blow if there is an internal short in one of the tubes (usually the power tubes), or if a power tube guide pin breaks off and the tube gets installed off key.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Could be a preamp tube that's arcing from plate to heater through the cathode material, putting b+ on the heater supply to ground via the 100R resistors. More common in CF designs, but worthwhile replacing the resistors and powering up without tubes. 1/8W seems fairly close and I'd expect them to fry eventually on their own without any other fault. 1/2W is more usual.
Does the amp work anyhow?Last edited by Mick Bailey; 05-04-2013, 12:36 PM.
