What and how do i determine what transformers to get for this schematic???
If your supply voltage is actually 300 volts, you need a 4K transformer, it's explained here The Valve Wizard -Single Ended and the example is an EL84 under 300 volts
Take your pick of output transformers from here. The Edcor looks like a bargain. Budget OPT's
The 20 watt rating is optimistic. You'll be lucky to get 10."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
There are serious problems with that schematic. It won't work as drawn. There is no practical way to get 20W through a 10K 10W resistor in series with the B+. The bias filter will produce a positive voltage and it won't work if you reverse the diode and cap polarity. The audio part of the circuit looks ok, sort of a Marshall 2203 feeds an EL34 Champ, but the power supply needs attention.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
I have some comments about the tube you've chosen, regardless of the power supply and amplifier gain.
Find some EL34 datasheets. From them you will see that while the tube dissipates 25W as a design nominal value, in single-ended mode the power that it can transfer to the OT is less, around 10W as Steve Conner mentioned. Having said that, guitarists and amp builders rarely stick with design center limits and you can get more than 10W audio power out. It won't be clean power, and there will be quite a bit of power tube distortion by the time you pass the 10W mark. Can you get 20W of audio power out of this amp? Maybe. Will it sound like a chainsaw by the time you reach 20W? Likely. Loud enough to smoke the pants off anyone in your basement while you play?
So don't expect 20W of clean power out of a single EL34. Won't happen.If it still won't get loud enough, it's probably broken. - Steve Conner
There are very few transformers like the one in the schematic that are available off the shelf. The Bridge rectifier is not used very often in tube circuits below 100 Watts. The bias supply has not been corrected.
There are hundreds of designs to be found on the internet that have been built and actually do work. Why are you so obsessed on this one? Can you make your own chassis? How do you intend to connect all the resistors and capacitors? Where do you intend to buy the components? Buying a kit will solve all those problems, and at a lower overall cost. If you simply must do it the hard way, get this book: TOT - Tonnes of ToneWARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Originally posted by ThKind View Postok thanks for the clarity will have to look a little deeper for some el84 power amps i guess?If it still won't get loud enough, it's probably broken. - Steve Conner
I've never heard of anyone that is sorry they built a Deluxe 5E3 kit as a first project. Bruce of Mission Amps sells one of the best.
A few pedals and this what you get - 100 Riffs (A Brief History of Rock N' Roll) - YouTube..Joe L
