Results 1 to 16 of 16
Thread: Kasino Fever Schematic
    New Member
    May 2013
    4
    0
    Unhappy Kasino Fever Schematic
    I'd like to find out where I can get a copy of the Kustom Kasino Fever amp schematics. My father purchased this collectible from a pawn shop and it quit working recently. Otherwise the case, etc. are in mint condition. My repairman cannot proceed without the schematic. Any help would be greatly appreciated.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,472
    Received: 2,024/7
    55
    Then your repairman will have to give us the board numbers. Kustom amp boards have type numbers on them, PC5033 or PC108 or whatever. We need those PC numbers, as that is how the circuits are identified. The "schematic" for an individual amp model is really just a wiring diagram for the connections between boards.
    There is a lot that can be done without schematics. We can usually verify power supply is present and clean. And if we have power, we can usually determine which section has the problem.
    "Stopped working" could mean anything. It would be helpful to know whether that means the whole thing is dead and dark, or if the sound no longer comes out the speaker, or if it still amplifies but sounds like crap.
    And it helps to know if it was failing for a while or if it worked OK and then just stopped instantly.
    ON an amp that age, all the small electrolytic caps in the signal path are suspect, and for the very small cost they represent, they probably ought to be changed, and that usually fixes half the old Kustom amps I see.
    New Member
    May 2013
    4
    0
    The board numbers are as follows : PC5033 AND PC5102
    32,472
    Received: 2,024/7
    55
    Let me see if uploads are working today...
    Got the PC5033 already scanned, I'll have to look in my files for the other.
    Attached Thumbnails Attached Thumbnails Kustom PC5033.pdf
    New Member
    May 2013
    4
    0
    Thanks so much!
    Old Timer
    Jun 2007
    5,112
    Received: 98/0
    Given: 60/0
    19
    Enzo, if you don't find it I can scan the one I have.
    It's interesting, I haven't heard of this amp in thirty years, and last week one came in for repair. Now here's another one. Interesting design with a sort of biamp output for the horn.
    32,472
    Received: 2,024/7
    55
    Go for it. Right now I have to fire up my old computer and shift various cables to do scans.
    Old Timer
    Jun 2007
    5,112
    Received: 98/0
    Given: 60/0
    19
    Here is the PC5102 schematic.
    Attached Files Attached Files
    3,853
    Received: 208/2
    Given: 20/0
    18
    Is the chip numbered an 80848 a CA3080? Given the pin 5 input, and the R35/R36 attenuator at its input, not to mention its role in the tremolo circuit, I'm getting that sense. BUt I'd like some confirmation all the same.
    Old Timer
    Jun 2007
    5,112
    Received: 98/0
    Given: 60/0
    19
    Quote Originally Posted by Mark Hammer View Post
    Yes, I've used a standard CA3080 as a replacement for that part. The originals all seem to be metal cased TO-5 versions, but the standard 8 pin dips fit the boards and work perfectly as well.
    New Member
    May 2013
    4
    0
    Smile
    Thank you so much!
  12. #12
    Jan 2013
    savannah,ga
    41
    Received: 1/0
    0
    not to hi jack the thread but a quick question if I may...on PC5102 my signal dies right after pin 8 of IC I1B. nothing on the other side of c22 and r30 which ties to pin 133 c 26 and c28.I suspect a faulty IC1 as cap and resistor both pass the test. looks to be a SL14228. any ideas for a sub.thanks gentlemen.
  13. #13
    Feb 2010
    12,030
    Received: 1,795/24
    Given: 4,615/11
    23
    SL14228 is a 4739 IC, no direct subs are available.
    You could try what is suggested in the following link, if you need more info please start a new thread.
    http://music-electronics-forum.com/t28734/#post253659
  14. #14
    Jan 2013
    savannah,ga
    41
    Received: 1/0
    0
    yes the 725 did the trick.pre board now operating fine.power amp output stage looks good too. thanks for the tip. now... here's the $64,000 question. what caused the IC 14228 to fail?
  15. #15
    Old Timer
    Jun 2007
    5,112
    Received: 98/0
    Given: 60/0
    19
    Quote Originally Posted by ogeecheeman View Post
    I really don't think that you can attribute the failure to any one reason. It could have been a manufacturing defect in the chip, it could have been a power line surge, a too large of a signal at the chip input, too much heat on one pin when it was soldered into the board, etc, etc.
    Now if every one of these preamp boards came back to the factory, all with the same chip blown, then there could be a design issue. Random failures can be caused by too many things to be guessed at. If you had access to a semiconductor lab, you could open up the case and find out what parts of the chip failed on the wafer. Then maybe you would know for certain why it failed.
  16. #16
    Jan 2013
    savannah,ga
    41
    Received: 1/0
    0
    kasino fever amp issue
    amp is back.different issue. input stage transistors Q1 & Q2 with 8vdc on all legs.???
  1. Kasino Lounge B Schematic Needed
    By AtomicMassUnit in forum Schematic Requests
    Last Post: 02-09-2012, 09:25 PM
  2. kustom kasino thermostat
    By nosaj in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-20-2011, 04:46 AM
  3. Kustom Kasino Fever diode replacement
    Last Post: 09-03-2011, 02:59 AM
  4. Kasino Little Joe need schematic
    By jessadr in forum Schematic Requests
    Last Post: 08-14-2009, 06:36 AM
  5. Kustom Kasino Club schematic(s) needed
    By Euthymia in forum Schematic Requests
    Last Post: 04-08-2009, 04:57 AM
