A friend picked up this beast for $50 at a swap meet. It had a PCB short between the OT feeds at the LO/HI power switch which I removed. But now it goes into ultra-sonic oscillation near clipping in the Hi power mode only. If I feed the FX Return, then it only oscillates a little bit on the top half of the waveform before it sort of punches through the oscillation at clipping. I've swapped tubes and even tried another OT, but it still acts the same. It does not oscillate with only 2 power tubes in place. With the power tubes out, the output of the PI looks good on a scope.
Any ideas?
Any ideas?
