KLDguitar PGA 18H power soak speaker emulation DI connecting with computer
  • KLDguitar PGA 18H power soak speaker emulation DI connecting with computer
    The KLDguitar PGA18H has many special features , which let PGA18H go from a roar to a whisper, shaking the boards on stage, tingling spines in the studio, and raising goose-bumps in the still of night - even during silent recording. Its three-step power soak brings the sound of the big stage into small clubs and your bedroom. Blending power soak with Pentode/ Triode, player can obtain from 18w to 0.5w power. enables a reduction of power from 18w down to 0.5w. With the built-in Red Box and silent recording capability, you can lay down pro-quality tracks at any time day or night.
    ·SMPT self monitoring tube matched status
    ·18 watts (rms) into 16 or 8 ohms
    ·Tubes: Two EL84s and three 12AX7s
    ·Pentode/Triode SW
    ·Power soak in 8ohm,18w, 5/18,1/18 and silence speaker.The max power is 18w, the mini power is only 0.5w.
    ·2-channel preamp
    ·Pre- post-gain controls on lead channel
    Normal volume control on clean channel
    ·3-band passive EQs(bass, middle, treble)
    ·Boost switch
    ·Footswitch selectable channel switching and reverb(select AUX)
    ·Speaker output jacks :4,8,16,2x8,2x16 ohm
    ·Red Box DI out(XLR Out)
    ·Spring Reverb with level control
    ·FX Loop
    ·Precise made parts used for lowest noise 5W metal oxide power resistors, 600V polypropylene film/foil and polyester military capacitors
    ·Metal heat-dissipating enclosure
    ·Connects with 112
    ·DIMENSION:
    46(L)x20(W)x27(H)CM(15.7"x7.9"x10.6") (Unpacked) 60(L)x32(W)x34(H)CM(23.6"x12.6"x13.4")(Packed)
    ·WEIGHT: 10kg/22llbs(Unpacked),14kg/30.8lbs(Packed)
    KLD PGA 18H 18w Tube amp head with Reverb
    Player: Niels Van der Steenhoven
