What are the effects of running AC mains parallel to the chassis? My DRRI had the power cord coming over to the switch and fuse on a big raised arc. I "fixed" this by running both hot and neutral along the bottom crease to the switch/fuse, and then back again via same path before taking a right turn to the PT. Since this amp now has a low level hum I can't find, I wonder if this method can induce unwanted current in the chassis, causing hum? And maybe the big incoming lines arc wasn't laziness, but for a reason?
AC mains dress
Originally posted by Randall View Post...maybe the big incoming lines arc wasn't laziness, but for a reason?
Originally posted by Steve Conner View PostAC mains dress sounds like something Lou Reed might have worn on the Transformer tour.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
