multi-tap speaker jack wiring
  • multi-tap speaker jack wiring
    Is it possible to reliably use the 4 and 8 ohm taps with two speaker jacks that will automatically switch between:
    8 ohm cab into 8 ohm jack, or
    4 ohm cab into 4 ohm jack, or
    two 8 ohm cabs into both jacks
    If not, what would be the preferred switching method?
    Thank you!
    On method that does not require a separate switch is to install two jacks wired in parallel connected to the 4 Ohm tap. Then you just know how that you can plug in two 8 Ohm loads to those jacks if it's your amp or you mark the panel so that others will have a chance of figuring it out.
      I can see how you can get two 8 ohm or one 4 ohm with this method Tom, but what about one 8 ohm speaker?
        A third jack would be wired to the 8 ohm tap, for use with a single 8 ohm cab.
        I like Tom's idea of using 3 jacks so no switch is required. But that would be the other option, 2 jacks and a switch to choose the 4 ohm or 8 ohm tap.
          YES! Thank you Tom and g-one. Three jacks, no switch, perfect. I knew I was making it more difficult than it needed to be. Thank you guys!
            Yep. Three jacks. I meant to state that but upon re-reading my post I find that I just thought it but didn't make it clear in the text.
            Cheers,
            Tom
              As I see it, an impedance selector switch only becomes beneficial (over the arrangement Tom describes) when there are 3 options required.
              eg 5 jack sockets to accommodate 4,8,16 as either single cabs or parallel pairs of 2x8 or 2x16.
              Pete
                You can also do this with 2 jacks and no switch: the 8-ohm jack is a standard open-circuit jack, and the 4-ohm jack is a transfer-type. (like this)
                Wire it up so the tips of both jacks are connected together, and connect both 4- and 8-ohm taps from the OT to the 4-ohm transfer jack, the 8-ohm to the normally-closed connection and the 4-ohm to the normally-open connection.
                Then when nothing is plugged into the 4-ohm jack, the 8-ohm tap is engaged and you can plug into the 8-ohm jack no problem. When you plug something into the 4-ohm jack, the 4-ohm tap is engaged, so you can use one 4-ohm or two 8-ohm cabs and only be using the 4-ohm tap on the OT.
                This is how they do it on my Peavey Butcher. It's pretty idiot-proof, but I'm personally not a fan of having switching jacks for speaker connections...up to you though, just my 2 cents.
                  I would avoid switching jacks as well. Sooner or later, they will be a problem.
