Why is it the input on most marshall style amps with cascaded gain stages have a 1M input resistor? Why not smaller?
why 1M input on most M style amps?
Originally posted by daz View PostWhy is it the input on most marshall style amps with cascaded gain stages have a 1M input resistor? Why not smaller?
One part not loading the guitar signal down to one part 1M is the traditional tube grid pulldown value, possibly an other part of "we're sure that with 100k plate resistors, 1M won't load it much".
I guess those all distill down to "doesn't load the source down much and doesn't need much thinking".
Can you point to a schemo and the resistors? If you can, I'll gladly opine more.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
If you like the tone, do it. It knocks off a little of the high end from the guitar, but then lots of people have liked that in the past, some quite famous and well thought of.
There is at least one commercial pedal that has advertising babble talking about how wonderfully mellow, less harsh, yada, yada that the magic box makes guitar sound. Inside are two jacks, a pot and a resistor so you can dial the pot down to load the guitar pickups more.
And people pay money for it, I guess.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
Your guitar volume pot is usually 250 or 500K and the volume regulation depends on its own taper, so if it's log ... it's plain log and it will work like that into an open load, or into a *large* impedance (such as 1M).
But if you load it with a lower impedance (220K to 47K) it loads it down, specially at intermediate volume settings, so you get an "enhanced log" response, with seemingly wider and smoother range.
If so, why isn't it used often?
Because too low an input impedance "kills" pickup "character/sparkle" and as you know, "tone" is more important than "convenience".
Yet some amps have low input impedance on purpose, "to make them more controllable from the guitar pot", such as a couple Mesa Boogie "Blues" amps.Juan Manuel Fahey
Originally posted by J M Fahey View Postloads it down, specially at intermediate volume settings, so you get an "enhanced log" response, with seemingly wider and smoother range.
Originally posted by Steve Conner View PostMy current favourite amp has a switch to select 1M or 100k input impedance. I've been playing it on 100k a lot lately.
I replaced the 1M grid load on one of my amps with a linear pot but I think that a switch between 1M and 100k would have worked just as well.
Steve AholaThe Blue Guitar
www.blueguitar.org
Some recordings:
Turning the instrument tone control down a bit (eg 7/8) acts to load the pickup and so damp its resonance somet.
PeteMy band:- http://www.youtube.com/user/RedwingBand
Originally posted by pdf64 View PostTurning the instrument tone control down a bit (eg 7/8) acts to load the pickup and so damp its resonance somet.
Pete
I played guitar for 35 years before I ever tried turning down the volume and tone controls- I always had them set to 10! No wonder I thought that most teles were way too harsh. Not too long ago I got a tip to start off with the tele knobs set to 5 and then play around with them until you get the sound you want. I think that is the reason that tele knobs don't have numbers on them.
SteveThe Blue Guitar
www.blueguitar.org
Some recordings:
The classic Fuzz Face has a really low input impedance and the real ones don't have true bypass so it's always loading the guitar.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Originally posted by loudthud View PostThe classic Fuzz Face has a really low input impedance and the real ones don't have true bypass so it's always loading the guitar.
www.blueguitar.org
Some recordings:
I believe it is Fuzz Face into wah. It simply doesn't work right the other way around, because the classic wah pedal had an unbuffered output.
My input impedance thing was actually inspired by Fender. If I read the schematics right, plugging into the "Lo" jack puts your signal through a potential divider made of two 68k resistors, for an input impedance of 136k and a 6dB attenuation. I found this was a tonal option I liked, so I put it on a switch instead of having a second jack. I used two 47k resistors.
I still use the regular 68k grid stopper at the other end of the wire leading from the front panel to V1."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
I think the Fuzz Face does have true bypass (maybe the wah was in mind?). Some Jimi fans apparently think the Univibe was used as a buffer between the wah and FF. Don't know if that is true, but a buffer does seem to help the two work together better.
Okay I looked it up and this was what he used at Woodstock (lots of people would have seen his rig that day so I think that it is correct.)
Guitar>Vox Wah>FF> Univibe>two Marshall stacks
Here is a link to the web page:
http://www.guitargeek.com/jimi-hendr...setup-diagram/
www.blueguitar.org
Some recordings:
