I get this all the time, and I agree: "My <Insert blackface/silverface Fender with verb> distorts too easy". What they really mean is, it distorts early on the pot taper. Usually by the time the volume is above about 2.5 a PAF will be dirty, by 5 you're talking the high side of blues gain. So for people who don't take a vintage Fender and crank it to 8 for their sound but use pedals and play clean or on the edge of breakup, I think I have a solution.
The issue is, how to give more control over the volume using more pot taper?
Here's my thinking, correct me if I'm wrong:
If we consider a pot not turned up all the way as 2 parts (2 parts of the voltage divider)
1) A series resistance with the input signal (between the input and wiper).
2) a load resistance to ground for the next stage (wiper to ground).
Now consider a 1Meg Audio taper (or fake audio taper) pot. At 3 on the knob, it is about 5% of the total resistance between wiper and ground, leaving 95% series resistance with the signal. At 5 on the knob it is about 10% with 90%, and the amp is distorting pretty well. So a 100k pot instead of 1Meg, with a 820k resistor between the output of the treble pot in the input to the 100k volume pot should approximate the range of 0-5 on the knob of a 1Meg pot, but give finer tuned control and more useful knob range. Yes 820k plus 100k isn't 1Meg, but neither are most of those old "1 Meg" pots either.
The load on the output of the treble pot stays about the same, as does the input load on the 3rd stage.
Does this make sense or am I missing something?
