Monitor Setup Using Aux Send Question HELP PLEASE !!
  • Monitor Setup Using Aux Send Question HELP PLEASE !!
    1. Behringer X2222usb Mixing Board
    2. Samson Servo-550- 275 watts (into 4 ohms) Can be Bridged into a 8 Ohm with full 550 watt power output.
    3. 2 Yamaha 12" Monitors with horn 8 Ohm Speakers ( for Git. & Vocals up frount )
    4. Powered 15" Speaker to be determined later. ( for Drummer )
    I have a behringer x2222usb. I'm using Aux 1 & 2 for monitors send. So 2 cables coming out of the mixing board to the left & right input of the amp in stero. Then out, with 2 cables to each speaker. But the Amp is Samson Servo-550 model delivers 275 watts (into 4 ohms) of power per side.The speakers are 8ohms Yamahas 12" .I want to run 1 more powered monitor to the drummer in back. Using the same Aux 1 for the same mix. Can I send a Y cable from that Aux 1, to run 1 amp and the other part of the Y to powered speaker in back??? Or maybe can you give me anouther way to hook up this monitor system. Im very new to this. I've been doing my very best to try and look for info online to get it up and running without burning anything out. Any help would be appreciated.
