TS-9 led question
  • TS-9 led question
    I recently did the true bypass mod with the blue 3PdT switch to a friend's TS that already had the LED replaced with a super bright blue one. Seems the combination of the two draws down the battery faster, and as an added bonus the super bright doesn't get dimmer, even down to 4 volts when the pedal sounds like poo. Friend wants the LED dimming feature back. Original one is gone. I want to put in a red one that will dim when the battery gets low, but I understand that the true bypass mod changes things a bit by removing the switching transistor and zener. What would be a good replacement LED for this that will not draw down too much, and will preserve the dimming feature?
    Friend is a high end guitar player, and the most sensitive player I know with regards to his gear.
    You could just put a resistor in line with the LED to knock down the current. Then he can still have his fancy blue led. If you run some wires out to a potentiometer first for experimentation, you ought to be able to get a resistor value that does what you are looking for. Otherwise, to my recollection, there's nothing special about the original LED except I believe they had a clear lens. Any standard LED should work.
      Typically, LEDs do not draw more than a couple milliamps; even the older less-efficient ones run at max brightness. Certainly the stock red one that came with the TS-9 wouldn't have drawn very much. Maybe enough to shorten the battery lifespan by 5%, but not enough to produce discernible battery drain.
      Contemporary superbright LEDs, like the blue one being discussed, can easily deliver more than enough visibility with 1/4 or less of the current draw that the original required. I can stick a 10-12k current-limiting resistor in series with one and find it more than bright enough.
      Recently, I made myself a little LED resistor estimator unit, using a 12-position rotary switch, a bunch of standard-value resistors, and a socket for the LED. The resistors go from 1k up to 18k. I turn the switch up to max resistance, insert the LED to the socket, connect the 9v battery, and turn the switch down until I reach the brightness that I find suitable. Then I select the common value, either a little higher or lower than where the switch is set to, that I think will "deliver the goods".
        Stock TS9 switch has an on board resistor to drop down current to led.
        If you replace it with a 3pdt wired for true bypass (with new wires to led) that res. in bypassed and so you must add a res on V+ (usuallyfrom 1K to 4,7K) to compensate things.
        Do that and your blue led will work properly w/o sucking so much current
        hot
          There is a resistor in series already. I think it's the fact that the more efficient bright blue LED doesn't dim when the battery is getting low that is the issue. So I guess any 'normal' red one will do.
            There's nothing that says you can't raise the value of the existing resistor if you like.
              Agreed.
              In the working circuit you want to be slightly above the knee voltage of the LED.
              Then a drop in the overall battery voltage will dim it.
