Results 1 to 5 of 5
Thread: Question on voltage: 120v/240v - Vox Venue Keyboard 100
    Feb 2010
    86
    I bought a Vox Venue 100 Keyboard amp new when I was stationed in the UK. I don't remember the specifics, but I bought it on a US Base there, possibly in the base exchange? I also don't remember if I ran it there using 240v or not. This was in 1986. I also bought a marshall jcm800 there, and it had a 120v/240v switch on it.
    Here is a pic of the amp (not mine): Click image for larger version.
    I shipped the amp back in '87, and have been running it ever since using a 120v plug and 120v US power. I've never had an issue with it. It's been gigged as a keyboard amp, bass amp and even vocals.
    For some reason I never looked at, or don't remember looking at the writing on the back of the amp. It clearly says "Mains voltage: 240v" - there is no switch to change it to 120v. I opened it up, and there is no internal switch. The PT is hard wired, it doesn't look like it was modified in any way (certainly wasn't by me, and I'm the original owner).
    Just wondering if there is any way to tell if the PT really is a 240v PT? Is there any harm in running it on a 120v line if it is? Been running for 27 years!
    Thanks.
    Feb 2010
    10,206
    Received: 353/1
    Given: 692/0
    If it were really meant for 240V I don't think it would work on 120V. Also you have a 120 type plug correct?
    It's possible they put a 120V sticker over where you now see 240V and it fell off over the years.
    Is there a mains fuse? What is it labelled as and what is it actually? A 120V amp would use a fuse twice the size (rated in amps) as a 240V model.
    Feb 2010
    86
    Quote Originally Posted by g-one View Post
    Hmmm, it may have had a sticker over that spot, but I don't remember. It has a fused IEC plug on the back, that's why I'm unclear on whether it had a UK style plug at one point. The IEC plug fuse is 2A, there is a 5A fuse just above the speaker jacks and two internal 5A fuses.
    Dec 2008
    Wernersville, PA
    12,362
    Received: 111/1
    Given: 31/0
    Check the main DC voltage rails.
    Should be about 50 volts.(strapped for 110V)
    If it's half (strapped for 220V) then there you go.
    Feb 2010
    86
    Quote Originally Posted by Jazz P Bass View Post
    50v/-50v - thanks, should have thought of that!
  1. replacing 120v with 240v transformer
    By elsquirrel in forum Music Electronics
    Last Post: 05-20-2014, 01:38 AM
  2. Behringer PMP1680s 120v to 240v ??????
    By metalgod_dave in forum Music Electronics
    Last Post: 08-22-2013, 12:35 PM
  3. Vox Venue SS Amp - DC on output
    By ggjgjhkihkjhiuyiy8788 in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-15-2012, 06:17 AM
  4. Ampeg SVT-CL 240V, fan voltage?
    By Zouto in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-01-2011, 07:50 AM
  5. Marshall 100 high voltage AC question
    By cortezthekiller in forum Build Your Amp
    Last Post: 05-06-2009, 04:56 AM
