Originally posted by The Dude
View Post
Please Help Me Trouble Shoot 64 Bandmaster
These photos help a lot, there are things here that are not part of the normal schematic. There are oddly mounted resistors on the power tube sockets as well, so please add photos of that part of the chassis as well.
The first two filter caps have been replaced with really high value caps. I wonder what the original values were?
Originally posted by 52 Bill View Post...The first two filter caps have been replaced with really high value caps. I wonder what the original values were?
The oddest thing seems to be the extra 220k resistors connected to the high voltage feeds to the preamp. These are the ones Bob was describing earlier. I have never seen those in a stock Fender amp and I can't figure out what the other end is connected to or why they are there. I have circled them in red on the attached photo.
The feedback resistor (circled in green) is supposed to be 100 Ohms but the color code in the photo looks like yel-blk-yel which would be way wrong. Maybe it's just poor resistor coloring or the lighting. Wish I could see it in person.
I think that is brown bk brown. It is a light brown, like tan, but look at the yellow on the resistors below it, it doesn;t look like them. I vote it is a 100.Education is what you're left with after you have forgotten what you have learned.
I also notice a small disk cap that has been added in parallel to a stock cap. One side looks to be unconnected and could be bouncing around making intermittent contact as the amp is moved / played. I'd remove it completely for now. It is circled in yellow in the updated attached photo. (Use the zoom to get a better look at the area)
Originally posted by 52 Bill View Post...There are oddly mounted resistors on the power tube sockets ...Last edited by Tom Phillips; 08-21-2013, 07:08 PM.
Originally posted by Tom Phillips View PostI also notice a small disk cap that has been added in parallel to a stock cap. One side looks to be unconnected and could be bouncing around making intermittent contact as the amp is moved / played. I'd remove it completely for now. It is circled in yellow in the updated attached photo. (Use the zoom to get a better look at the area)
I think those are the grid stoppers mounted the way it's done in old Marshall amps. They don't appear to be the 1,500 Ohm standard Fender value. However, quite a wide range of resistance values will work in that position just fine.This isn't the future I signed up for.
As far as the extra 220K's by the plate resistors, those extra eyelets have to be there for some reason don't they? There is nothing shown there on the AA763 layout, so I assume those boards did not have those extra eyelets, can anyone confirm?
If that is the case, can anyone think of a version that has extra eyelets in those positions?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
My comments about the filter caps and the grid stoppers was meant to point out things that I saw that were different, like the 220K resistors and the double caps in the treble circuit of the tone stack.
My point was that I've never seen a stock Fender grid stopper hung in the air like that, and that it would be nice to see some better photos of that area of the amp.
The schematic for the AA763 shows the first filter caps as being two 60uF caps in series without the balancing /bleeder resistors. This one seems to have the bleeders installed.
I'll leave this one to you guys.
Why are there two caps in series in the tone stack - the domino and the disk (250pf)? Layout has a jumper where the domino cap is located. Was the jumper removed? If not the domino cap isnt doing anything."In theory, there is no difference between theory and practice. In practice there is."
- Yogi Berra
Originally posted by g-one View PostAs far as the extra 220K's by the plate resistors, those extra eyelets have to be there for some reason don't they? There is nothing shown there on the AA763 layout, so I assume those boards did not have those extra eyelets, can anyone confirm?
*If that's the case, DAB you have the option to leave the circuit as-is, or you could do a little mod, leaving the xtra components in place to audition what it would sound like with the more commonly found circuit.
Quick mod - lift one end of the 220K and wire a jumper around the domino cap. Then have a listen. Should be a bit brighter.This isn't the future I signed up for.
The rest of the amp is in OK shape for it's age and it should be no biggie to restore it to original operation.
The photos really help Bob. It would be good to see the other whole side of the chassis. I'm wondering it it has all the original transformers. Also please bring us up to date on the issue you have with the current sound of the amp.
Originally posted by Leo_Gnardo View PostOkay, now that I've seen it, can say I've seen it before, I think on a white Tremolux...
Originally posted by dumbassbob View PostThere is a sheilded wire instead. They are intentionally disconnected.
I think you should bring the speaker and speaker cable, because I have a feeling that's part of the problem.
I mean, you could have closure, once and for all, instead of the ongoing-on and on- headaches.
The offer is open...and you are welcome to stop in.
Originally posted by Tom Phillips View PostCool input Leo. Although I have seen lots of anomalies in the old Fender amps this one is really obscure. I looked at the Tremolux service info I have and don't find it documented anywhere. No yet anyway.
OK back to the task at hand... and yes the speaker cable & speaker, its cab & internal wiring are all in question too, right on SGM !This isn't the future I signed up for.
