Results 1 to 5 of 5
Thread: Did i damage my amp?
    Junior Member
    May 2007
    13
    0
    I went to a friends house with my TSL head, plugged into his cab, and the volume was insanely low. Long story short, it turns out his speaker cable has a short between the two wires inside, while still allowing the cab to work (quietly). After returning home, I plugged it into my cab with a good cable, and the volume seems normal, but the amp seems to have slightly less gain and more bass.
    Does anyone know what could have happened or what I could test?
    Thanks in advance
    Old Timer Amp Kat's Avatar
    Jul 2006
    Baton Rouge,LA
    1,492
    14
    Quote Originally Posted by slacker190 View Post
    it turns out his speaker cable has a short between the two wires inside, Does anyone know what could have happened or what I could test?
    Thanks in advance
    Short or open ? A short won't hurt anything but an open could have caused damage to the OT but you would have known as it wouldn't play at all. I can't think of anything it would have done to change the sound.
    KB
    Junior Member
    May 2007
    13
    0
    The tip and ring (- and +) of the jack have continuity between them when tested with a multimeter.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    31,252
    Received: 1,188/7
    53
    You are measuring the resistance of the output transformer. It is OK.
    Junior Member
    May 2007
    13
    0
    After playing the amp today, it turns out one preamp tube was going south on me, which equates to the change in tone. After replacing the preamp tube, the amp is back to normal again.
    Thanks for your help.
  1. Will bass damage a valve amp?
    By willvdw in forum Tubes (Valves)
    Last Post: 08-30-2007, 12:53 AM
  2. Water damage Peavey Artist 240
    By casiocreature in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-01-2007, 12:07 PM
  3. 50hz vs 60hz Damage?
    By liquidjap in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-18-2006, 03:07 PM
