Ampeg BA115 weird problem fixing poweramp
  • Ampeg BA115 weird problem fixing poweramp
    Hi to all ,
    I have here an Ampeg BA115 with shot outputstage. Removed the screws from the powertransistors, unsoldered them and looked rather stupid.
    I can not remove the power-transistors! It looks as if they where mounted with a pad to the heat sink. And they won't move a bit.
    Not even when using a little of force.
    Anyone any advise for me, how to get rid of the parts (without destroying the whole amp ;-)) ?
    thx in advance
    greetings from austria
    Gerhard
    The transistors are 'stuck' by the silicone paste.
    A small drift pin in the mounting hole can be used to pry up the component.
    The transistor case is plastic, so wacking on the side of it is not a good idea.
    Unless you know the part is truly faulty.
      Yep! thx!
      The transistors are mounted on little light-brown pads. Obviously the pads
      held the cases on the heat sink. I think I am a bit too scared of damaging something.
      The transistors are completely faulty. I think I will replace the pads too.
      thx Gerhard
