I decided to start a new thread as my original issue was resolved as I discovered my bonehead move that was causing blown fuses.
OK this may or may not be an issue as I am not familiar with these LTD 400 amps but when the volume is turned low (say 1-3) there is a noticeable distortion when playing guitar. Almost as if I have a light overdrive pedal on.
However, when the amp is turned up from 3 to full blast the distortion actually clears up producing a loud, clean tone that actually sounds very good. Is this normal for the LTD? I would assume there should be NO evidence of distortion even at very low volume settings?
Anything I should suspect or check with this issue?
