Hi am needing schematic diagram for Behringer Ultrabass BX4210A or something similar for a freind to fix my amp. send to my email if you cant post thankyou
Ultrabass BX4210a
A bit more descriptive text would be useful here rather than a tube video i.e. what the fault is and what you are trying to achieve.
Tracing back the connections with a continuity tester should give you a rough idea.
My guess of what that 6 pin connector carries is based on the BVT 4500h.
Plus and minus 15v supply and power supply ground. (Pins 1,3 & 2)
Output from pre-amp post master vol and audio ground.(Pins 4 & 5 )
Limit L.E.D. drive from power amp. (Pin 6)
Hopefully someone has had hands on experience with this and or the correct diagram.
