Dynacord Powermate 1000 MK1
  • Dynacord Powermate 1000 MK1
    Hello, I've seen requests for this before but I am unable to get one. I need schematic for MK!.
    It goes straight to protect on switch on. All o/p transistors tested ok and all voltage supply rails are good.
    I took speaker connection direct from the board before protect relay and music was a bit distorted and low power on both channels. Any help out there?
    Quote:"I took speaker connection direct from the board before protect relay:
    Is there a dc voltage on that point?
    That is what usually drives an amp into protect.
      i dont know if this is the mk1 or not, but maybe it will help
