Results 1 to 21 of 21
Thread: Ampeg V-6B Transistor Substitutions
    Oct 2012
    Austin, TX
    70
    8
    So I've got an Ampeg V-6B on the bench, and I need to replace the 2 driver transistors, and they are impossible to find. The schematic says NA under part substitution. I can't find ANY info online about their specs. I've pretty much exhausted all known resources. Even contacted Ampeg, and they are even more clueless. I talked to another local tech today and he recommended that I mod the circuit to accept current production transistors. This is out of my out of my area of "expertise". I know there was a similar thread somewhere online about this exact thing, but it stumped everyone. Enzo, you even chimed in on it. You're pretty much the jedi master with this stuff, so i'm hoping to hear from ya. The transistors in question are STA8236 (Q302-npn) and STA0202 (Q303-pnp). Btw, when I first opened it up, D210 & R216 were blown to bits. I'll try to post a schematic and some pics in a minute. Anyway, if anyone has any insight for me, I'd love to hear it. Thanks!
    Oct 2012
    Austin, TX
    70
    8
    Here's the schematic and the transistors I need to replace:
    http://i1223.photobucket.com/albums/...ps46d52f83.jpg
    http://i1223.photobucket.com/albums/...psd422e81e.jpg
    I took a picture of the schematic thats inside the amp instead of posting one from a website, because they're all so grainy online its too hard to read. I zoomed in on the last one to give you guys a better look at Q302, Q303, D210, & R216, since those were the trouble spots. Fyi, I've replaced all electrolytics, all 8 power transistors, a few diodes and resistors, and a few of the smaller transistors hoping that it would solve the problem since I can't find the drivers. Now, when I play it, it works, but only at very low volume. Turn it up slightly and it distorts and makes loud "coughing" noises. Same noises happen when I tap or jolt the amp at any volume. Solid State is such a pain to work on.
    Sep 2013
    central Italy
    81
    7
    Those old TO-66 metal can types are just about impossible to find these days, but modern TO-220 types can be substituted without problems.
    Use the MJE15030 (NPN), MJE15031 (PNP), just be sure you get the original ON and not some chinese knock-off.
    Sep 2013
    central Italy
    81
    7
    Oops. Didn't see your edit before I posted.
    Noises when you tap or jolt the amp point to bad solder joints or intermittent plug connectors. Make sure to get this sorted out first.
    Tap the circuit board(s) all over very gently with the handle of a small screwdriver or other suitable (insulating!) implement. With some luck you can pinpoint the area where the bad connection lurks. Inspect all solder joints in the area for defects, if a joint looks suspect, resolder it. If necessary, remove excess old solder from the joint.
    Since this is an old, pre-ROHS amp, use 60/40 Sn/Pb solder rather than the ROHS-approved lead-free alloy.
    Oct 2012
    Austin, TX
    70
    8
    Thanks flyingdutchman!! That's what the local tech suggested as well. He just didn't know which ones were ok to use since there aren't any specs for the old ones. He said to make sure I get matched ones. So here are my questions (sorry if they are stupid): Are you positive those parts will sub for the old ones? What do you mean by "ON"? How do I make sure they're matched? Transistors are sorta my kryptonite. I know how to test them with a diode tester, but that's pretty much it. I'm understanding them more as I work on SS amps, so hopefully I'll learn something from you guys.
    Oct 2012
    Austin, TX
    70
    8
    Yeah, I've poked around all over the place and haven't heard anything, and even resoldered a bunch of joints for good measure. All I use is 60/40 or 63/37. Lead free sucks. Anyway, I should probably keep poking because you're probably right. Hell, it's a small enough board that I should just hit everything with fresh solder. Its for a close friend, so I don't mind being super thorough.
    Sep 2013
    central Italy
    81
    7
    "ON" stands for "ON Semiconductors", which is the semiconductor manufacturing division spun off by Motorola. Motorola, and hence now ON, are the original manufacturers of the MJE150xx series.
    You do not necessarily need matched transistors in most solid state amps. If you run a bank of power devices in parallel you'd want them to be more or less in the same ballpark but that's about it. If a power amp will not work correctly unless you use matched complements for drivers, it means you're dealing with a very badly designed amp.
    How you match transistors depends completely on which parameters you'd want to match. Long story.
    Sep 2013
    central Italy
    81
    7
    Other things to watch for when amps make noises when jolted: Bad control pots, bad switches, loose fuse holders, faston (spade) connectors and so forth.
    Oct 2012
    Austin, TX
    70
    8
    That's interesting about the loose fuse. That's worth looking into. Here's a pic of the original fuse before I replaced it. It was a bitch getting it off, so I clipped the leads and soldered a new leaded fuse to the old lead. It's definitely soldered to the leads, but I wonder if It's bouncing around. Hmmmm. I'll get back to you on that one. And thanks again man. You're being incredibly helpful. I really appreciate it.
    Oct 2012
    Austin, TX
    70
    8
    Ok, so you got me thinking. Aside from the fuse, the filter caps might be suspect. The original ones were massive. New replacement caps are like half the size, and there are holes in the side of the chassis to clamp them in that are way too big for the new caps. Finding a way to secure them in the big holes was a challenge, and they might not be as secure as I hoped. I'll show you.
    And here's the new fuse I put in:
    The caps are only held in with one screw. I bent the clamps so that they press firmly against the chassis, holding the caps in place. That's the best I could do. I thought about it a long time, tried rigging it several other ways, even looked for extra space elsewhere that I could somehow secure them to, and nothing else really worked except the way I have it now. This problem takes creativity. If i had a way to do it, I would cut some metal with smaller holes in them to mount over the old ones, but that didn't seem practical. Anyway, do you think the way I have the fuse and caps are problematic? And if you have some clever tricks for mounting those caps, I'm all ears.
    Old Timer
    Jun 2007
    5,107
    Received: 92/0
    Given: 57/0
    19
    The old TO-66 case transistors are hard to find now. The TO-220 transistors will fit into the same sockets or pc boards by cutting off the center Collector lead and bending down the Base and Emitter leads.
    Did you test the transistors that you are trying to replace? Have you tested the other transistors in the power amp?
  12. #12
    Sep 2013
    central Italy
    81
    7
    The internal fuse shouldn't be a problem as long as the solder joints are OK. Do check the panel fuse holder for loose contacts though.
    As for the PSU caps, I wouldn't leave them "hanging" like that. Get out your metalworking tools and some alu sheet and make an adapter plate with smaller holes such that the caps are properly supported.
    Consider that the cap on the negative side of the supply has -Vcc on the can, if the insulating sleeve gets damaged for some reason you might get a nice short against the chassis.
    The thing I usually do if I have to replace PSU caps, given that chassis mount types are increasingly hard to find, I make a simple PCB to hold the caps. Sometimes the new caps are small enough that they fit inside the chassis, otherwise I just have them poke through the chassis holes for the old ones. I admit though, that this solution is practical only if you're set up to make your own PCBs.
  13. #13
    Old Timer
    Jun 2007
    5,107
    Received: 92/0
    Given: 57/0
    19
    Quote Originally Posted by flyingdutchman View Post
    I agree, but you could just use blank perfboard to make adapter plates that the new caps can mount on.
    If you have a larger hardware store or industrial supplier around, you might find standard flat washers that can be modified to work as an adapter plate. 2-2 1/2" diameter washers are fairly common.
  14. #14
    Oct 2012
    Austin, TX
    70
    8
    Thanks everyone for helping me out. Flyingdutchman, I tested those transistors, and they're ok. I must have done it wrong the first time. I poked around and found the source of the distortion. It was a wire connected to one of the transistors in question. So that's fixed, but I'm still getting a loud popping sound, either after a few seconds after warm up, or after touching random wires. So it's gotta be a solder joint or wire. I've replaced several wires and touched up lots of solder joints that seem to make noise when I touch them, but everytime I think I found the problem, it still comes back. I'll just have to keep poking around. I'll let you guys know. And the caps are actually held down pretty damn good.
  15. #15
    Old Timer olddawg's Avatar
    Dec 2007
    La Jolla CA, Hanalei, Kauai
    2,977
    Received: 286/0
    Given: 30/1
    14
    Quote Originally Posted by evil79 View Post
    Lots of things can cause pops. I couldn't read the schematics but if it has a difamp input its beta matched pair of transistors could have drifted. Small capacitors could do it and also could any component with physically intermittent connections internally. Do you have a scope? I would try a heat gun and some freeze spray to isolate the problem. If you tickle a difamp pair and there is a problem it will let you know, lol.
  16. #16
    Oct 2012
    Austin, TX
    70
    8
    I do have a scope, but I still don't know how to use it. I have a signal generator that I downloaded on my phone, if that is ok to use. My question about the scope is, how do I make connections from the scope to the amp? I can possibly figure out the rest if you can help me with that. I know its a dumb question, but scopes have eluded me so far and I can't find anyone to teach me. here's what I have.
  17. #17
    Sep 2013
    central Italy
    81
    7
    That's a very nice scope. A lot better than the old Hitachi I have to make do with
    Anyway, in the bottom pic, on the right, there's a probe. On the left, there's what looks like a ground lead.
    Plug the probe's BNC connector into the CH1 input of the scope. Plug the ground lead into the hole between the CH2 and CH3 inputs. Clip the other side of the ground lead to the chassis of the piece of gear you're working on.
    Power up the scope.
    Set TRIGGER HOLDOFF to OFF, TRIGGER LEVEL centered, TRIGGER MODE to AUTO, TRIGGER SOURCE to CH1
    Set the main MODE selector (between CH2 and the SEC/DIV knob) to A.
    You should see a horizontal trace appear across the screen. Also, the scope will show its settings on screen.
    Set Vertical Mode to CH1
    Adjust A Inten(sity) such that the trace is nicely visible but not too bright.
    Adjust FOCUS such that the trace is as neat as possible
    Hook the probe tip onto the CAL eyelet.
    Fiddle CH1 VOLTS/DIV and POSITION, and SEC/DIV until you get a nice square wave on the screen.
    Observe what each control does.
    The probe has a little switch that says X1 - X10. In the X10 position, the probe attenuates the signal by a factor of 10. At the same time, the input impedance goes up from 1M ohm to 10M ohm. This is useful if you are measuring in high impedance circuits and you want to avoid loading down the circuit you're measuring on. It is also useful if you're measuring the output of a large power amp, which wouldn't fit on the screen otherwise. In the x1 position, the maximum amplitude you can visualize is something like 100V peak-to-peak.
    The inputs have an AC/DC setting. In the AC position, the channel will ignore DC voltages so a small AC waveform riding a large DC offset won't make the beam disappear from the screen.
    These are the basics, more or less. Experiment and have fun. See if you can find an owners manual for your scope, this model has lots of neat stuff, way beyond what a simple scope like mine has.
    Learning to interpret what you see on the scope is another matter still, it takes quite some experience.
    Oh, and whatever you do, STAY WELL CLEAR OF ANYTHING CONNECTED TO THE MAINS VOLTAGE. Unless you're using an isolation transformer, anything between the mains lead and the power transformer is strictly off limits for the probe.
  18. #18
    Oct 2012
    Austin, TX
    70
    8
    Thank you so much! How about the signal generator? It's an app on my phone. It has 20Hz-20kHz adjustable frequency, volume from -60db to 0db, and either white noise, pink noise, or sine wave. I would go from 1/8" jack from my phone to 1/4" input to amp. Will that work, or do I need a fancier generator?
  19. #19
    Sep 2013
    central Italy
    81
    7
    It should work without any problem at all, and it's more than fancy enough for most audio work.
    For testing instrument amps, a good setting is 500Hz, -20dB.
    Myself, I use a very simple home-brew sinewave generator which goes from 10Hz to 31.5 kHz in calibrated 1/3 octave steps. It has a 0dBV output level, which goes into a home-brew three-stage calibrated step attenuator that goes to -80dB in 0.5 dB steps.
    I also have a little pink noise generator. I've built this stuff more than 15 yrs ago, and I've been getting by quite OK thank you.
    I do have a proper function generator, also home-brew and now more than 25 yrs old, I use it only in the very rare occasions I need a square or triangle waveform, but this is mostly when I'm doing stuff that's not strictly audio related.
  20. #20
    Oct 2012
    Austin, TX
    70
    8
    What about the black lead that is clipped to the side of the probe? What do I do with that? and where should I start probing in the amp?
  21. #21
    Sep 2013
    central Italy
    81
    7
    That's the probe ground lead.
    If you can use the chassis ground lead, the probe ground lead is superfluous and can be removed. Or maybe I should say, should be removed. Otherwise, it may get in the way and since it's connected to ground, if it accidentally contacts something in the equipment you're working on (like supply lines or whatnot) a nasty short could result.
    If you have to work with high frequency or very feeble signals, it's better to use the probe ground rather than the chassis ground wire.
    If both the scope and the equipment under test are powered by three-pin grounded mains sockets you might be able to dispense with the ground connection altogether especially if the sockets are next to each other.
    Note however that some equipment may not have a solid connection between signal ground and chassis ground. In that case, you must connect either the probe ground or the scope chassis ground wire to a true signal ground, such as the sleeve of the input jack.
    Be careful with speaker output jacks, the sleeve might not be signal ground.
  1. Ampeg v-6b multitap inductor replacement ideas?
    By Alex R in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-21-2012, 01:28 PM
  2. Ampeg B115 Transistor Suggestions
    By Jecarroll7 in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-23-2012, 05:48 PM
  3. Ampeg transistor?
    By drewl in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-20-2011, 03:15 PM
  4. Boss ME-6B micro switches?
    By Whitey-on-the-moon in forum Guitar Effects
    Last Post: 03-31-2009, 12:56 PM
  5. 6AQ5 substitutions
    By EETStudent in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-12-2008, 05:29 PM
Tags for this Thread
