Hello. I have a CE1000 that is making a low volume hum on both channels. The volume level of the hum does not change with adjust of the input pot. Both channels are producing audio but at a much lower volume than they should. Any ideas on where I can look would be greatly appreciated. I have downloaded the documentation from Crown and have begun to wade through it. Thanks..
Infamous CE1000
#1. Check each & every power rail.
If both channels are humming, the common item is the power supply.
Also, the main board screw pads must be clean & the screws tight.
Three of the screws are a common for grounds on the amp.
I just repaired a C-1000 with a blown channel.
Whooee.
Surface mount city.
Which main board number does the amp have?
The board schematic is for the 127452-4.
Link: http://www.crownaudio.com/media/pdf/..._serv_revd.pdf
It starts at Page# 576.
Make sure that you do the 'Bootstrap Resistor Mod".
That is covered on Page# 548.
You add a 1K/ 5W resistor on the white wire.
The 127452-4 has the circuit change.
If you do remove the board for powering up, you must connect the three mounting holes that are shiny to the common ground.
Also you will need to make 3 jumpers to extend the bridge rectifier wires.
Oh, if you do remove the board, mark down were the wires go.
You do not want to reconnect it wrong.
The white wire that goes to the middle of the main board will have to be unsoldered to remove the board.
(This is the wire that will get the 1K/ 5W resistor)
Resolder it when testing (or the led's will not light)
And don't forget to remove the fan header.
The screws are Torqx by the way.
I had a chance to a take a deeper look at the CE1000. The voltages all appeared to be normal. I measured the +/- 98VCC and the +/- 15 VDC. Both appeared to be normal. What tolerance should I be looking for on the voltages. The + 15 was just under 15 and the -15 was just above. Also Should I look at the voltage divider voltages that right above the +/- 15 VDC circuit on the schematic? Did I miss any other voltages that I should check? Thanks.. -Tabmo
So the DC voltages check.
Flip your volt meter to read Volts ac & test them again.
You will be looking for any voltage rails that have any Vac ripple on them.
The main rails expect a little.
What the + has, the - should have.
The + & - 15 Vdc rails should have zero ripple.
What you are doing is testing the supply capacitors ability to filter the rectified voltages.
Oh, do the blinking led's turn off at power up.? (they should)
And does the 'Protect LED' go out (it should)Last edited by Jazz P Bass; 10-21-2013, 10:12 PM.
Jazz P Bass. Thanks for the response. I was thinking that maybe one the caps was not acting like a cap. I was also thinking I was going to have to find an o-scope to look at them. I did not think of using my meter. Good idea.. I believe the LED's are acting normal. Thanks.
