dropping resistors not dropping
  • dropping resistors not dropping
    Hola mi amigos, I powered up my build for the first time yesterday only to discover that for some reason all of my HT voltages were sitting at B+; the dropping resistors weren't dropping.
    6550 plate: 460
    6550 screen: 460
    12ay7 plate: 460
    12ax7 plate: 455
    12ax7 plate: 455
    There's a 5.6k 10 watt resistor that should be dropping the screen and 12ay7 to about 310, and a 10k 2 watt that should be dropping the 12ax7 voltages. Its as if the tubes aren't drawing current at all. There's a 12au7 for a reverb driver that hasn't been put in yet so I expected them to be sitting a little high but this is clearly a bigger problem. Any hints?
    I wired an ammeter between the power primaries and switch, it says its only drawing .6 amps. The 6550 heaters alone should be pulling more than that. Anyone have a helpful hint on where to start?
    Were the tubes plugged in? (I ask this because some builders expected the voltages to drop without tubes.) Were the tubes filaments lighting up? Do you measure about 6.3VAC between the heater pins or about 3.15VAC to ground.
      Yeah tubes are in and I see 6v between the heater pins
        Is ground hooked up? Measure the cathode voltages on the preamp tubes.
          ok so not sure what's up but i walked back down to my shop to measure the cathodes on the preamp and magically the voltages across the HT have begun dropping. I'm thinking grounding issue, cold joint or something like that. This is what I measured when I walked down-
          B+: 400
          6550 plates: 377
          6550 screens: 180
          12ay7
          PI plate: 162
          PI cathode: 25
          12ax7
          V2A plate: 162
          V2A cathode: 1.7mV
          12ax7
          V1B plate: 148
          V1B cathode: .7V
          12ax7
          V1A plate: 173
          V1A cathode 142mV
          v2b is the recovery stage for the reverb and hasnt been wired up yet. i didnt expect my B+/plate voltage to be this low with load either. hope i dont have to go back to the drawing board
