Page 1 of 2 12 LastLast
Results 1 to 35 of 39
Thread: What's the purpose of R105 in the Hot Rod Deluxe 2 tone stack?
    Mar 2011
    161
    I mean: the 220k resistor parallel to the bass pot and which goes to ground, unlike in a typical Bassman tone stack...
    In my understanding of self-taught hobbyist, it increases the Q of the mid dip and slightly shifts it down, giving more low mids & high mids... hence these frequencies between 800hz & 2khz which certainly "cut" the mix but don't sound Fenderish to my humble ears...
    if it has also any technical utility, I'll be grateful to learn something new. :-)
    Thx in advance to confirm, correct or complete my thoughts (I plan to mod the amp, so I don't want to damage it because of something that I wouldn't have understood).
    Dec 2008
    Wernersville, PA
    12,347
    Received: 102/0
    Given: 30/0
    Huh.
    I never took notice of that resistor.
    It would seem that it would make the bass & mid 'interactive'.
    http://www.blueguitar.org/new/schem/...deluxe_pre.gif
    Mar 2011
    161
    Quote Originally Posted by Jazz P Bass View Post
    Huh.
    Thx for your answer.
    Whatever is does, it "squeezes" the spectrum and boosts the high mids in an unpleasant way.
    Having already soldered a jumper across the mid pot, I plan to clip this 220k resistor, therefore...
    Opinions and advices welcome. :-)
    Supporting Member
    Staffordshire UK
    3,425
    Received: 85/0
    Given: 83/0
    Doesn't it just limit the max bass?
    But in that case they could have got the same effect by using a 100k bass control.
    I don't see how it does all this other stuff mentioned, especially altering the Q of the mid scoop
    Pete
    Mar 2011
    161
    Quote Originally Posted by pdf64 View Post
    Pete
    My first thought was that it limits the bass. Then I've used the .tsc calculator, trying to take in account how this parallel resistor interacts with the serial resistance of the T/B/M pots : I've ended with a curve whose mid dip was narrower, whatever is the reason.
    Anyway, I've clipped R105 today then tested the amp with a frequency analyzer: there's slightly less bass now ; the bowed curve between 800 & 2000hz is gone too. And the mid dip looks a touch wider. The amp finally sounds like a Fender...
    I've also mounted a pre-gain bright switch on the volume pot, with a 120pf cap: it adds sparkle above 4khz and completes the stock bright switch, which created a peak @ 4khz.
    Maybe I'll change C1 the next time but I'm done today. At least, now, I've shared my results with you, folks. :-)
    Senior Member Pedro Vecino's Avatar
    Jul 2006
    Spain
    513
    Received: 21/0
    Given: 13/0
    When I tried it many years ago (by ear) I understood that this resistor was there basically to keep a certain amount of mid frequencies presents avoiding emphasize the lows independently. This makes sense in a pre-drive equalization circuit to maintain the integrity with that rudimentary overdrive. In other words: although is common to both channels is related to the lead channel response to avoid excessive contrasts between bass and mids.
    Not sure if that matches what you have obtained with the analyzer. That was my observation
    Old Timer
    Jun 2007
    5,000
    Received: 16/0
    Given: 13/0
    Also note that if you are trying to get back to "typical" sound, the slope resistor R12 is 130K and not the usual 100K.
    Mar 2011
    161
    Quote Originally Posted by Pedro Vecino View Post
    Thx for this info!
    I must admit that I focus on the clean channel: I use drive pedals with it. I keep the onboard drive as a spare only. So, I've not yet tested its response. I've just played the yellow and red modes, and noticed that the sound was correct with moderate settings.
    Thank you to remind me that parm. Actually, I'm reluctant to change it because I'd have to change the tone caps too... Of course, the 22n cap is "off" compared to a typical Fender schematic but according to .tsc, it can give something close to a 47n cap as long as it is used with the 130k resistor.
    Footnote: I've just changed C1 for another polarized cap (25 / 35v). The amp sounds noticeably cleaner. I've to play it, now. :-))
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    5,223
    Received: 308/0
    Given: 247/0
    Quote Originally Posted by 52 Bill View Post
    Uh oh... you found part of my secret tone-fattening formula. For those who complain about "too bright" I reduce the value of R12 first thing, and easy enough to parallel another resistor to R12 without having to tear the whole board out. In fact I aim for 33K to 68K as the value for the composite resistor.
    Old Timer
    Jun 2007
    5,000
    Received: 16/0
    Given: 13/0
    Back in the '80s when Fender had those blackface amps with push pull switches on all of the pots, they had changed that resistor to something like 150K and then had a switchable parallel resistor to get the value back down to 100K.
    Jul 2006
    Spain
    513
    Received: 21/0
    Given: 13/0
    I do not remember any Fender that use that system. Could you tell what model?
    I've seen in Rivera amps (called "notch" if not remember bad). To avoid the high voltage on the switch requires prior isolation of a capacitor.
  12. #12
    Old Timer
    Jun 2007
    5,000
    Received: 16/0
    Given: 13/0
    The ones that I am thinking about are the Fender 30 and the 75, probably designed by Rivera when he was with Fender.
  13. #13
    Dec 2012
    177
    That resistor in the tonestack is probably what others have said about it, but you mentioned, after you took it out, it sounds like a fender...
    There are other issues with the tonestack that aren't fender styled... SO if you care, I'll point them out. The slope resistor (130k) to be like a BF twin would be a 100k. the mid pot would be a 10kl wire like this: jumper the wiper of the mid pot to the top of the mid pot (like on the bass pot) remove the 200k (like you already did.) and the .022 cap on the mid pot, is wrong, unless you want a super reverb tonestack, because only on the super reverb did they put a .022 cap to the mid pots. The twin and the deluxe etc. , had .047. The .022 will give you a good amount more low-mids than a .047. Try it in the TSC. Hope this helps. Again, the biggest mod out of all these ones I just pointed out, would be the 220k (but you already did that) and the jumper from the wiper and the top of the mid pot, it will get a way more fendery response and tone. Even without the other value changes. Also with a 100k slope resistore vs 130k you will get more bass and mids than before which might be nice, which you can always roll back a little bit more than before anyway.
  14. #14
    Dec 2012
    177
    I missed this post the first time through... So anyway, you like 33-68k for the slope resistor? How does that work for you, does it ever get flabby or too much? I've not tried messing with that resistor before although I've tried pretty much everything else. Also how do you think it would work to put separate resistors in there one for bass and one for mids, so I could get a touch more bass, but a good amount more mids? I've also not tried that, you don't even see that on anything.
  15. #15
    Sep 2012
    Dogpatch-on-Hudson
    5,223
    Received: 308/0
    Given: 247/0
    Quote Originally Posted by isaac View Post
    Sort of pushes the EQ curve closer to tweed tonestack. By suppressing the upper harmonics, it allows more fundamentals and lower harmonics to come through. Has a bit to do with psycho-acoustics. If there's too much treble, the ear tends to ignore the lower frequencies. Yes, it can get flabby, depending on where the tone controls are set, what speakers, what guitar pickup etc. Too much bass in any tonestack brings on the flab. Many of my customers are looking for robust tone, even fat (blues guys & gals, also jazzers), but just shy of flabby. (I take flab to mean so much bass that it overloads the power amp, obscuring a clear tone.)
    Haven't tried that, but I have put in switches to select stock or other value "slope" resistors in some mods. Sunn used to include a "contour" pot in some of their tonestacks - you could vary the slope resistor to any reasonable value.
  16. #16
    Dec 2012
    177
    I've thought about dueling the mid pot to vary the slope resistor in a small range, and use the mid pot like usual. I'd just have to reduce the value of my pots to make both pots reasonable values. But I'm very familiar with reducing pot values with resistors. Oh yea, tweed? That's interesting. Now what if I try this... Think twin reverb preamp, right before the 250pf and the 100k meet, between there and the plate of the tube, i actually in one design have a .047 cap, it was just to keep the plate voltage away from the tonestack, in this one particular design it just needed it, not for the bass though, but what if I put a cap after the volume control to reduce bass a little overall if the slope mod is too much. (still on a twin reverb type preamp.) It's not a fender amp, its a custom something or other i built, but thats the idea.
  17. #17
    Mar 2011
    161
    Thx to you and Leo_Gnardo for your helpful replies!
    I understand what you say and I agree. Simply, the 130k slope resistor + the 22n mid cap appear to give the same curve than a Fender tone stack with a few adjustments.
    As an attached file, I post a picture about it. Green curve= typical Fender tone stack, all controls @ noon. Orange curve = BMT controls @ 6, 3, 6 with the HRD tone stack as I've modified it for the moment (jumper on the mid pot, 220k additional resistor removed, all other parts intact). As you can see, TSC draws a similar spectrum although the settings and components are different. It's "good enough for me" right now.
    I'll jusst have to try the amp in rehearsal, in order to decide if it requires further mods or not to my ears. :-)
  18. #18
    Dec 2012
    177
    Ok, you did you do the jumper wire on the mid pot. Big difference huh? If you wanted it to be the most fenderesque you could go crazy and blackface the amp... at least in the clean channel, but i haven't heard of anyone doing that... Anyway, Hope you like it, and make sure you tell us how it has worked out for you.
  19. #19
    Sep 2012
    Dogpatch-on-Hudson
    5,223
    Received: 308/0
    Given: 247/0
    Quote Originally Posted by freefrog View Post
    I'll just have to try the amp in rehearsal, in order to decide if it requires further mods or not to my ears.
    Thanks for the mention AND the chart!
    Keep us posted, LG.
  20. #20
    Supporting Member Tone Meister's Avatar
    Aug 2012
    North Carolina, USA
    645
    Received: 16/1
    Given: 13/0
    Yeah, I'm also interested to know what you think of these changes after playing the amp a while. What mid cap did you end up with?
  21. #21
    Dec 2012
    177
    The .022 will give you more mids in general, also a little more low mids than before, as compared to the regular mid increase. I'm tempted to put a second .047 in parallel with my first one so I'd get kinda about .022, but when I do it, put a dual pot on so I can control the mids, but Also control how much that cap is paralleled in so the more I increase the mid pot, the more the mids actually increase. But yes, Tonemeister, he should be getting a very blackface style tone. Should sound very close. Please make a youtube or sound clip where we can hear it. Hopefully you have a clip from before the mods.
  22. #22
    Aug 2012
    North Carolina, USA
    645
    Received: 16/1
    Given: 13/0
    The .022 will give you more mids in general, also a little more low mids than before, as compared to the regular mid increase...
    I presume that you mean with the R105 220K resistor removed, because the stock value for the C6 mid cap is 0.022 uF. I've been using an 0.015 here, and recently an 0.02 when I ran out of the 0.015. I'm always interested in hearing what others are doing in these amps and why.
    Isaac, can you elaborate a bit more on your comments?
  23. #23
    Aug 2012
    North Carolina, USA
    645
    Received: 16/1
    Given: 13/0
    Additionally, I'm looking for a way to increase headroom reasonably in the clean channel without having to perform major surgery.
  24. #24
    Old Timer
    Jun 2007
    5,000
    Received: 16/0
    Given: 13/0
    Check your theory here about paralleled caps.
  25. #25
    Dec 2012
    177
    Sorry 52 bill, I meant series caps with a pot to bypass it. And Tonemeister, I forgot that the standard value was .022, but I was talking mostly if you use a BF twin tonestack and then mod from there. Sorry for confusion guys. And Tonemeister, I'll look at the full schematic see what headroom helps I might be able to direct you to... For clean channel headroom... Some tweaks, Change the first cathode cap to a 25uf instead of 47uf. Replace volume pot with 1MA, and you may want to take out the bright circuit on the second cathode cap. And reuse the switch for a regular bright cap on the volume control, you'll probably want it on the clean channel volume. then replace that cathode circuitry with a 820 ohm resistor in parallel with probably around a 5-10uf cap. You could go lower if you think it's too bassy. Also, I've never actually tried one of these amps, but I hear that the drive channel is really dark and unusable. In which case I'll take a small peak at that... try removing the 250pf cap and the 1M resistor that are in series at the grid of the third stage. and change the .047 cap at the master volume in the drive channel for a .022 and then get rid of the 390pf cap on the master. Now again, I've not tried this amp, nor have I worked on one, but I know many people say they have bad drive channels, so these are theoretical mods. Also the schematic you posted above says the PI is standard blackface type so two 1M resistors, a 22k and a 470 resistor right? Does the amp have a 12ax7 or 12aT7. If its a 12ax7, try a 12aT7 that should help, with headroom, and maybe even overall tone. Hope some of this helps.
    Once more, I haven't worked on or tried this amp, its theoretical, although the clean channel is pretty basic and I've worked on so many other ones, but I haven't worked on many drive channels. I've done several but not many, so please forgive me if something doesn't sound good, or it didn't work out.
  26. #26
    Junior Member
    Apr 2018
    7
    Hello Freefrog. Real nice and interesting post. I have just registered to this Forum just to know more about the mod you mentioned (clipping R105)
    I already have done the jumper mod to the mid pot, I leaved the R12 130K, changed the value of C1 to 2,2 uf and I am very interested in clipping R105, but I would like to know if you have new info about this mod?
    This amp is HONKY sounding and I suspect this could be a remedy.
    Also you mentioned something about the .022 uf tone cap,which I imagine is the mid cap. Did you tried the .047 uf in there? Do you think a .033 uf (half way between .022 and .047) would be a good idea in order to achieve a more BF sound with less mids?
    Im writing from Venezuela, your answer is very important for me.
    Thanks in advance
  27. #27
    Junior Member
    Apr 2018
    7
    Quote Originally Posted by Tone Meister View Post
    Hello Tone Meister
    When you used the 0.015 uf cap and later the 0.02 uf for the mid cap,what did you noticed? more mids, less honky sound, more BF sound?
    Thanks in advance
  28. #28
    Junior Member
    Apr 2018
    7
    I think using a 12AY7 in the V1 will help o a lot. Also it seems to me that changing the C1 value from 47uf to 22 or 10uf will help.
  29. #29
    Mar 2011
    161
    Quote Originally Posted by alga View Post
    Thanks in advance
    Hi alga and welcome !
    Removing R105 adds some bass but as I said above, it also tends to change the "openess" of the curve IME. Pic below.
    Yes, the amp is naturally honky.
    Yes, I've tried a 47nF mid cap. It works but makes it a bit too qwacky IMHO/IME if other mods are not done... Paradoxically, a 15nF mid cap wouldn't necessarily be worse if the goal is to have less honk (questions of clariity aside). I've never tried a 33nF in this position.
    FWIW, one of the most useful things that I've done with the tone stack of the HRD has been to put a 220k switchable resistor in parallel with the treble pot, lowering its overall value to 117k (IOW, I've somehow moved R105 elsewhere, in order to control other frequencies). It opens the curve more than simply clipping R105, by taming the high mids.
    I'll share other measurements and tricks ASAP... Life is busy for me right now.
    In the meantime, see the measurement below: it's the EQing curve of the HRD (clean channel) captured from the FX loop with R105 (white curve) then without it (black curve), measured a few years ago...
    Hope to be useful. :-)
  30. #30
    Junior Member
    Apr 2018
    7
    Hello Freefrog
    Thanks for the welcome. Im so happy and excited you answer me.
    I saw the chart and hope to see more difference on the curve with and without R105.
    Yes I found this amp honky and dont like that. I think that Fender amps has 2 traditional and characteristics sounds (black face and tweed) BF are mid scooped and tweed mid humped. I found the Hot Rod Deluxe and Deville are more toward the tweed sound but maybe with way more mid hump than Bassman, bandmaster etc etc
    My goal with this amp (maybe will sound crazy) will be to reduce or eliminate the honkyness which will somehow resemble a bassman sound. After acheiving that would like to know if its possible to make a mod with 1 or 2 switches for blackfacing the Hot Rod taking out lot of mids. The final outcome will be a very versatile Fender amp with a terrific mid humped sound (without honkyness) and on the other hand at least an aproximation to the BF scooped sound, I know technically is impossible to obtain 2 different circuits from just one, but with an aproximation to the BF Ill conform.
    If what I said is somehow possible and makes sense, from your experience what should be the first step? Im eager to hear the tricks you mentioned and also more details of the 220K in parallel with treble pot and the relocation of R105 etc etc
    So so grateful with your help
    Thanks in advance
  31. #31
    Mar 2011
    161
    Hi again Alga,
    I've took the same road several years ago... the HRD is probably the amp that I've modified the most - with a variable success and less rewards than with my other amps, sadly and FWIW.
    Mine currently includes three additional switches and a new "variable NFB" pot on the back pannel... I'll share with you a depiction of the related mods ASAP.
    Regarding the BassMan voicing, I've tweaked the drive channel in a way that I find satisfying and that I'll explain you later.
    Regarding the clean channel, I'm still not totally satisfied but I've found that [a resistor (ideally a trim pot) in series with a cap] parallel to R9 is a good way to "tune" the tone. It's even possible to implement a "contour" control there. Again, more later about that.
    Now, I'd find difficult to recommend a mod as a first step: if you "blackface" the tone stack without altering the rest of the circuit, you might find the clean channel too dark and thumpy... if you do a second mod to correct that, the "honk" might come back...
    A problem with this amp is that its stock EQ has been designed to match the Tweed style 1x12 cab and its resonance: even if the circuit is tweaked to approximate a Blackface, it won't sound like an open 1x12 or 2x12...
    Here is the frequency response of my uber-modified HRD upon the curve of a "real" Fender Twin Reverb RI: this time, the frequency response has been captured through a direct box between power amp and cab:
    BTW, the green and pink lines under the frequency response translate the distortion generated: it's something to keep in mind, since a same EQing with a different distortion curve doesn't sound the same at all.
    In this case, the HRD distorts less because I've fitted it with a 12AY7 in V1 (the Twin has still its stock 12AX7's). But the result is similar.
    In fact, these curves are close enough to make my HRD "Twin" sounding... but only through the cab of the Twin. Once played through its own cab, it returns to its HRD sonic footprint...
    Now, it's true that with lits imited value, size & weight + its solid 40w of power, the HRD remains a good amp for live sessions - reasons why I often take mine on stage.
    Hope to be useful. See you later!
  32. #32
    Junior Member
    Apr 2018
    7
    Hi again Alga,
    Freefrog
    Woao! Im so excited. Interesting we have practically the same goal to achieve with this amp. We have the same tube (12AY7) in the V1. We both soldered a jumper across the mid pot and also changed C1, lot of things in common looking for our goal.
    I tried to blackface the amp and happend exactly what you describe. Too dark (lot of high frequencys lost) not cutting well in a band situation, and too much thump due to change the R12 from 130k (carbon comp) to 100k (metal film).
    Very eager to know details about your mods, especially for the attenuation you invented for tamig the strong high mids in R9 and how did tweaked the drive channel. I guess changing C23 C11 and putting a 12DW7 in the V2.
  33. #33
    Mar 2011
    161
    Freefrog
    Hi again alga,
    I've still to write a diary of the mods done on my HRD: it would be useless to describe these changes one by one, since they work as a whole...
    IF you want to avoid a long tedious (and always risky) mod session on your amp, the simplest thing to do might be to replace R9 with a 1,5nF cap in series with a 100k resistor (exactly like in the stock drive channel). It would give a tighter/brigther clean tone, close to the clean channel in the Blues Deluxe RI (which involves even lower value caps, since it is fitted with a 10n followed by a 100k resistor, itseif plugged in a 750pF cap... in this case, the bright cap is another 750pF, switchable, over the 100k resistor).
    If ever you notice some "blocking" distortion, put a resistor of a few hundreds of k between the output of this network and the ground, just like in the BDRI.
    Of course, it would look more "professional" to swap directly C18 for a 1,5nF cap, but leaving it as it is and putting it in series with another 1,5nF cap would give practically the same result (since 22nF in series with 1.5nF = 1.4nF)... and it would allow to do that mod without pulling out the whole PCB (which is a pain in the @).
    Regarding the drive channel, don't waste your time with C11 & C23: I've changed these ones then came back to the stock value.
    Instead, you might try to tweak the gain and its bandwidth because that's where is the real main problem with this channel IMHO. Here is what I've done for that:
    -C8 replaced with a 1k to 1,8k resistor paralleled with the 1 cap (I migth have reduced R17 but since I've tried various cathode caps, it was simpler for me to add a resistor directly next to C8).
    -C9 = 1k in series with 1.2k paralleled itself with the second switchable cathode cap (22).
    -R21: 1k (if memory serves me. Not sure on this one but that's probably what I've done, in order to obtain a global cathode resistor value recalling the usual 820 Ohm).
    Useful tool if you want to adjust these components to your taste:
    https://www.ampbooks.com/mobile/ampl...or/calculator/
    Oh, and...
    -R19 value halved. Done with a second resistor of the same value than the stock one, in parallel with it.
    All these tweaks can be done with some careful "pig tailing" if necessary. It doesn't look nice but it avoids to hurt the frail tracks of such a flimsy PCB...
    "More later"... :-)
    EDIT -
    Below is the response of the modified clean channel in my HRD, vs the EQing of the stock preamp, captured from the FX loop output. Settings were the same: all controls at noon, volume @ 1 or 2/12.
    I add the response of the whole amp (captured through a DI box between amp and cab) when it's excited by a polyphonic signal, in drive mode (yellow channel), compared to the response of a Bassman, normal channel, same settings.
    Again, "more later", if time permits - in the meantime, alga, I've tried to send you a PM: check your mailbox. :-)
  34. #34
    Mar 2011
    161
    Below a photoshoped schematic of the network that I've added in parallel to R9 in order to obtain from the clean channel the preamp EQing pictured above (also due to the blackfaced tone stack, with a slope resistor R12 of 100k and a R105 clipped). Trim pot to adjust to taste (should be fine somewhere between 160k & 100k)
    [Click image for larger version.
    And here is another possible mod, with its theoretical effect on the bandwidth, to put again in parallel to R9...
Name:	Mid contour control.jpg
    "More later", maybe. :-)
  35. #35
    Mar 2011
    161
    Oh, and...
    My bad, I've apparently mixed up my notes with those regarding another amp... :-/
    Here is EXACTLY what I've done with the Drive channels - V2 being a 12AX7...
    -C8 swapped for a 1k resistor in series with a 1 cap (polarized).
    -C9 replaced by a 1k resistor in series with [a 1 cap parallel with (a 1k resistor in series with a 100nF cap)]. It forms a stepped cathode cap
    -R21: 820 Ohm (1.5k makes it sound too grainy and thin with the 12AY7 that I've put in V1)
    -R19 value halved.
    Master cranked and gain under 4/12 = clean on the verge of breakup, on the two channels.
    Gain full up and master lowered= a decent approximation of cranked classic Fender amps.
    The "more drive" channel distorts hardly more than the other... but my goal was precisely to make the two channels comparable in gain (and volume) with different voicings. Now, the yellow channel recalls a Bassman while the red channel is somewhere between a cranked Deluxe Reverb and a Marshall.
    These change don't pretend to make sense without the other mods done to the amp (blackfaced EQ and a few coupling caps changed elsewhere in the circuit + the mods mentioned above, among others).
    FWIW...
  1. Hot Rod Deluxe 6L6WGC too hot?
    By MickeyB in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-01-2014, 05:31 PM
  2. Fender Hot Rod Deluxe
    By bsco in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-29-2012, 01:01 AM
  3. Hot Rod Deluxe III tone stack issue.
    By jvm in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-25-2011, 06:00 PM
  4. Any Hot Rod Deluxe Mods out there??
    By Ringwraith in forum Mods & Tweaks
    Last Post: 05-08-2010, 07:33 PM
  5. Hot Rod Deluxe is too hot (accoustically)
    By lmolter in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-01-2008, 02:40 AM
