Gallien Krueger GK-210 "V" Schematic
  • Gallien Krueger GK-210 "V" Schematic
    I have a GK-210 Schem, but the unit i have in the shop is a bit different.
    GK-210V is the print I need. On this preamp board is an IC U6 (DG419DJ). It's a switching Ic. This Ic is not in the diagram of the GK210 print.
    I found a shorted DG419DJ Ic (loading down the +15v line on the preamp board).
    Amp has other issues, so I was hoping someone here has the correct version schem I need.
    Thx in advance
    Here is a the schematic I referenced for this preamp and it covers many of their lines. The U6 DG419 can be seen at quadrant C1 area on the schematic. Best of luck! :-) Hope this schematic is what you needed.
      That should work
      Thx much!
