A friend asked me to look at a pair of speakers, jbl g2 15. Turns out they have a quite noise going, a hiss coming from the high (treble) speakers. Anyone here familiar with these. Is it worth trying to fix?
EON jbl g2 15 - Hiss
Well, seeing that they are 500 bucks new, I would say 'yeah'.
The first thing to check is if it is a preamp or a power amp issue.
The Hi Freq output ic is a LM3886.
The schematics can be found here: EON-G2 Series
Originally posted by Jazz P Bass View PostWell, seeing that they are 500 bucks new, I would say 'yeah'.
Pre och power section? The noise is quite evident with speaker volume at 0. When I looked at it I just assumed that it is the power section.In this forum everyone is entitled to my opinion.
I'm hoping you are talking about a lot of hiss. Normally if I don't hear some hiss from a tweeter I suspect it may not be working.
This fault is occurring in both units? Seems a bit odd they would both have the same fault at the same time.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
They were bought cheaply way past any warranty. I just figured I help out if I could. It would just be nice to hear if someone here actually knew anything about these speakers or frequent causes for a lot of NOISE in them.In this forum everyone is entitled to my opinion.
Check that all the controls are working properly. The only EON's that I've worked on had almost all bad pots. A volume or treble pot stuck on full would put a lot of hiss through the tweeters.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g-one View PostCheck that all the controls are working properly. The only EON's that I've worked on had almost all bad pots. A volume or treble pot stuck on full would put a lot of hiss through the tweeters.In this forum everyone is entitled to my opinion.
