'53 Tele Bridge Spec's
Originally posted by Phil Gerke View PostThanks for sharing Jim. Can you explain what the mT is? There is quite the disparity between this 53' and the 57' you put up before.
Phil
The level of magnetic field strength or magnetic flux density. 10 Gauss = 1 mT (millitesla). I will no doubt be corrected on this one.Take Care,
Jim. . .
VA3DEF
____________________________________________________
In the immortal words of Dr. Johnny Fever, “When everyone is out to get you, paranoid is just good thinking.”
Originally posted by big_teee View PostAlso were these Dead pickups.
I didn't see a DCR?Take Care,
Jim. . .
VA3DEF
Originally posted by kayakerca View PostBoth the '57 and '53 bridges were dead Terry. I'm guessing the rust on the Alnico's just ate through the windings.
I've had several vintage pickups go through here, but it was always for rewind purposes.
IMO if they are rewound, they are Pickups, if they are dead, they are just Junk!
Or maybe paper weights!
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
TTake Care,
Jim. . .
VA3DEF
I've been winding some Tele Pickups lately.
Was wondering what height between flats most guys shoot for.
On most of my pickup data I find listed .500" between the flats.
That seems too tall for my liking.
I notice the OP has documented the .46, .47" between the flats IMO I think that is tall enough.
The pickup is plenty big to put lots of wire on.
I've also tried different baseplate, bare, Zinc, and copper plated.
I can't tell any difference, except the bare steel likes to rust.
I also noticed that the Tele pickup estimator neck, and bridge do not show the same turns results that I come up with?
The neck turns vs DCR seems high in turns, and the bridge seems low?
Part of that may be the wire specs used on the estimator is different than modern day wires?
TLast edited by big_teee; 08-19-2014, 09:28 PM."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
