hi good day to everyone... im having problem with my behringer pmp5000,the right channel(speakon connector) located at the back, is not giving balanced sound,
the sound output from this channel is very low while the other channel is giving normal sound,,, but the led indicator is giving equal signal... but the sound output is not.... i tried to change the connection but the speaker connected to the right speakon channel is still very low... what seems to be the problem...
*the speaker connected on left speakon channel is giving normal sound while the right speakon channel is giving very low sound only*
take note this mixer is powered... and im using the powered channel of the mixer
the left right panning is at 12' o clock position which means balance
i already checked the wiring and tried other wires but still same result
i also used other speaker and still same result
but when i used powered speaker it works fine because it is connected to other outputs like main 2 output or mon output (pl jack connector)
so my conclusion is this, the right speakon channel is giving low sound output unlike the left speakon channel is giving normal sound output...
so guys what do you think is the problem with my mixer...
pls i need a quick response this is my bread and butter
im using it on my band rehearsal and sound system rental business...
my customers are complaing about this problem...
thank you all guys and God bless
