Does anybody have the schematic for a Kustom KPM7250 powered mixer?
Kustom KPM7250
Not for this request. Last time I contacted them, I was told to contact an authorized Service Center. When I did, I was informed that they weren't authorized to release Kustom schematics and that I should send the unit in question (at that time) to them for repair.
What I've found so far: not passing a signal, power supply appears to be good, an apparently bad 13 pin STK404-140 power transistor -has DC voltages on most pins, including the output pins (but not the input); and the R28 resistor is partially blackened/charred: measures 500 ohm out of circuit, pcb location is marked "180", first two color bands are still visible and are green brown (which doesn't jive with the pcb marking); and one of two 4558 Opamps has DC voltage on all 8 pins -trying to trace the circuit for that one. Could really use a schematic, if I could find one.
