Fender Twin Reverb (ab763) motorboating?
  • Fender Twin Reverb (ab763) motorboating?
    Hi all,
    Been a long time since I posted but I haven't been away (just out of sight). After rebuilding a '73 Twin Reverb I've completed all sorts of other projects and recently build my first amp from scratch (a 5e3 Tweed). I must admit I couldn't have done it without the ton of information that I found on this site. Thank you all for sharing your knowledge with the rookies like myself.
    Although there is a lot of information available, there is a problem I can't find the answer for. My '73 (100w) Twin I rebuild to AB763 specs is working perfectly and I'm loving the tone, there is only one problem. When I turn the reverb past 8, out of nowhere a incredibly loud and low pitched rumble occurs. It seems like it feedbacks only difference is, it is a low pitched tone. The sound is suddenly there and (very loud) doesn't slowly swell up. I tried different reverb cans and swapped tubes (to no avail). Is there a point where I should start looking? Maybe the Reverb coupling caps? I build the the circuit on a turretboard using orange drops and f&t caps.
    Thanks!
    Try pulling the reverb tank out of the bottom of the cab and further away from the speaker magnets. Any difference?
      If not that then try replacing the cathode bypass cap on V4.
      Pete
        This weekend I had some spare time and looked further into it.
        I had another twin around so first thing i did was (double) checking if it wasn't a hardware or tube problem. I tried the cables+reverbtank from the other Twin and the same problem occurs (at the same setting). After that I tried the using the preamp tubes from the other Twin to rule out any tube issues. I also checked the values of the resistors int he reverb circuit and changed the cathode bypass cap (the cap connected from pin 3/8 on V4 to ground). This didn't help as well.
        Is it possible that the problem I'm having might be a ground loop/wiring issues? Which isn't really an issue unless I dial the reverb up past 8?
          The low frequency tells me it's in the power supply.
          Have you recapped it.
          If not, I would look at the plates of V3 & V4 A for ripple.
            Yes. THe amp has a completely new board. All resistors, capacitators, pots, tubes are new. The only salvaged parts are the chassis, transformers and tube sockets. The amp is built on a new turretboard. Come to think of it, the power supply is newly built on the original eyelet board using the original resistors that were still there. I will look further into the power supply section. The amp works perfectly well and almost no hiss or noise. This revebr problem is the only issue to be resolved and I would be 100% happy with it.
