Hi All, I'm working on a silverface super reverb, and noticed that the volume controls don't silence the guitar. In fact, even turning all the knobs all the way down doesn't. There's a dirty, quiet guitar sound present at all times if I play. Any ideas? Grounding out the grids of the first preamp stage silences it... All grounds seem to be good, 0 or 1 ohms...
Super Reverb Volume Controls won't Silence the Guitar
What is the resistance between the 2nd stage grid (=vol control wiper) and ground with it turned down?
Are the cathode bypass caps good?
Have you tried different tubes (V1 and 2)?
PeteMy band:- http://www.youtube.com/user/RedwingBand
Originally posted by AtomicMassUnit View PostHi All, I'm working on a silverface super reverb, and noticed that the volume controls don't silence the guitar. In fact, even turning all the knobs all the way down doesn't. There's a dirty, quiet guitar sound present at all times if I play. Any ideas? Grounding out the grids of the first preamp stage silences it... All grounds seem to be good, 0 or 1 ohms...
Because of the type of pots, the wiring, and the location of the ground to the chassis, there is no 0 ohms to ground on the volume controls. It's the grounding. Also I suspect some of the parts bleed into each other on the circuit board, probably the larger ceramic disk caps that were used in these particular year amps....
Certain years of Super were made this way, and it causes audio to bleed thru even when the controls are turned to zero. The audio is distorted when the volume is down, that's normal also.
You will also notice that amps made this way have a "better" sound, and are more aggressive sounding than other Fender amps of the era.
For Blues, it grinds better, has a better high end bite, and also more Hiss, the bass controls work better..etc...than other Fenders of that era.
I would not try to "fix" it. but rather accept that it is made that way. Also, because of the unique tone, certain guitar player may like it better than other year Super...
I have worked on 2 of these type Super in the last 3-4 months. I think they sound better than other ones. They definitely have some kick and distortion that other Fenders don't have. They seem to want to grow up and be Marshalls instead of Fenders...
Once long ago I asked the same question and was told "this is why Fender knobs only go down to 1, not zero". Not sure if that is the real reason but it works for me and helps me remember that it's pretty common with vintage Fender stuff.
It always helps to keep real world conditions in mind, what need is there for an amps volume to go to zero?
Also, 1 meg pots may not always go down to a perfect zero ohms, and are often bypassed by a bright cap.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I addressed this problem for a studio @ 20 years ago. First, many volume controls don't go all the way to zero when turned all the way down. Old controls often read 50 to 200 ohms. New ones, 10 to 20 - better but still not perfect. Measure some new volume pots, and pick the ones that go closest to zero, and substitute them for the ones in your amp.
There's also signal leakage within dual-triode preamp tubes. Here's what I did to "fix" that. Instead of using one triode as the first preamp stage, and the other as post-volume control gain, I swapped wiring around so that V1 tube handled both channels' first stage pre, and V2 both post-volume control gain. It wasn't perfect but it did reduce the problm to acceptable levels.This isn't the future I signed up for.
I don't have a ton of experience with these amps but I've seen this problem before. As mentioned, it was leakage within the tube itself. Replacing the tube for the offending channel fixed the problem. Other contributing factors could include old, high esr power supply filters, dirty pots, leaky coupling caps and oxidized ground connections (especially mechanical, not soldered connections) Not a huge problem since the amp isn't likely to be played on zero very much."Take two placebos, works twice as well." Enzo
Originally posted by JoeM View PostMy SR does the same thing with certain tubes. Try a different tube in V1 or V2 as mentioned above.
