Got given a Carlsbro marlin amp that doesn't work. It's a 6-150 mkII. It's early days but looking inside there are two blown fuses and two green wires with rings on them not going anywhere of which I am assuming connect to either the chassis or one of other to an output transistors (MJ02)... ?? The MJ02 transistors test ok with a multimeter although the collectors ( transistor cases) aren't connected to anything and insulated from the chassis? I don't know much else at the mo other than the transformer now disconnected tests ok. Any help would be great thanks. Simon.
Carlsbro Marlin Amp
