Hello, long time lurker first time caller shall I say. I've gotten the inspiration recently to look into building myself a new coil winder. I had one I built when I was 15 that I used for a number years until I started working on amps, when unfortunately it was latter scrapped while I was moving from my old place to where I am now. Anyways that winder did work but it was somewhat crude, one problem I had was that I never figured out a reliable method of guiding the the wire onto the bobbin. With the bit of research I've done thus far I've seen the schatten pickup winder and it's coil guide and I think it would work perfectly for what I want to do. So my question is what are those parts called? As in when I go the hardware store, what should I be looking for? The smooth rod will be easy to find, but what are the guides themselves called outside of the pickup makers world? I've attached a pic for quick reference. Thanks for your time.
A quick question about coil guides/traverse limiters
Originally posted by capehead View PostHello, long time lurker first time caller shall I say. I've gotten the inspiration recently to look into building myself a new coil winder. I had one I built when I was 15 that I used for a number years until I started working on amps, when unfortunately it was latter scrapped while I was moving from my old place to where I am now. Anyways that winder did work but it was somewhat crude, one problem I had was that I never figured out a reliable method of guiding the the wire onto the bobbin. With the bit of research I've done thus far I've seen the schatten pickup winder and it's coil guide and I think it would work perfectly for what I want to do. So my question is what are those parts called? As in when I go the hardware store, what should I be looking for? The smooth rod will be easy to find, but what are the guides themselves called outside of the pickup makers world? I've attached a pic for quick reference. Thanks for your time.
[ATTACH=CONFIG]26887[/ATTACH]
Hi capehead:
Welcome.
The pieces are called shaft collars or stop collars.Take Care,
Jim. . .
VA3DEF
____________________________________________________
In the immortal words of Dr. Johnny Fever, “When everyone is out to get you, paranoid is just good thinking.”
