I'm wondering if there is a way to wire the output on a Bassman to use an 8 ohm speaker. I want to use a single 12" and the choices are limited in a 4 ohm.
Is there a way to use an 8 ohm speaker with a Bassman
You have a couple of easy options:
a) Just use the 8 ohm speaker with the 4 ohm amplifier output
b) Wire an 8 ohm, 25 watt power resistor in parallel with the 8 ohm speaker, so that your net load is 4 ohms.
I would go with the first approach. An 8 ohm mismatch is not really a bad mismatch for a Fender bassman. The amp will probably tolerate the mismatch quite well."Stand back, I'm holding a calculator." - chinrest
Originally posted by bob p View Postb) Wire an 8 ohm, 25 watt power resistor in parallel with the 8 ohm speaker, so that your net load is 4 ohms.
As I'm finding myself in exactly the same situation, I've been trying to find solutions.
(Here's my thread: http://music-electronics-forum.com/s...ead.php?t=3543 )
Basically it says that in my research I found this:
https://taweber.powweb.com/store/zmatch.htm
Which looks useful, although it's usefulness hasn't been proven.
Weber also make a autotransformer for this purpose. I don't know anyone who's used it though.
Originally posted by harry View PostWould this be a safer option, in that it'd put no strain on the amplifier at all? I regularly turn my amp up to max, and sometimes I have to use an 8 ohm load instead of a 4 ohm load. I'd like to be sure that it's not doing my amp any harm.
Just plug it in and rock. I have two SF Bassman heads that I abused for over 20 years with an 8 ohm load.
