need schematic for Blackstar HT 1B
  • need schematic for Blackstar HT 1B
    Blackstar HT1B see no filament on tubes, cd input seems to work. Need a schematic thanks.
    you can follow the filament without a schematic
    but make sure the power is unplugged
    open it and see if there is a filament fuse
    many of the new amps have a filament fuse
    between pins 4-5 and 9 on a preamp tube, you will usually see 6.3 volts AC
    sometimes the filament is powered by DC on the same pins.
    If you are unfamiliar with measuring, have a tech do it for you.
      I think that the heaters are 12Vdc.
        Right on JPB!... In the HT 5 the positive 15 volt rail for the I.C.'s is also used to power V1 dual heater/filament .
        It's a 1 watt 15 ohm resistor and my guess is, that's what's faulty!
