I know enough to position the transformers at opposing directions to avoid magnetic field interference between them, but what about proximity? Will this be ok or are they too close to each other?
Quick transformer layout question
Too close...I modded a Bogen CHB100, and they mounted the transformers close like that. In a stock Bogen it is fine but when you increase the gain, it hums....best to mount further apart, and really there is the trick where you can wire up the PT and then fire it up with all the secondary leads disconnected, and listen with headphones to the OT speaker connections, (but leave the primary disconnected)while you move around the OT to get the lowest hum....it works well...
Greg
