Tube amp project
  • Tube amp project
    It's been a busy few nights, here's what I have done so far. I am getting a lay-down style bell set for the PT and should be able to start wiring this weekend.
    I'm using a Yamaha B100ii solid state head cabinet because in actuality, I like it and I got it dirt-cheap. The Tolex is in great shape but I will be replacing the grille cloth.
    I cut out the area of the chassis that had all the funky stamping and holes that weren't going to work and replaced it with a piece of aluminum sheet, then drilled the tube mounting holes.
    --Jim
    He's like a new set of strings... he just needs to be stretched a bit.
    Before even reading the post I thought "hey, that's Yamaha grille cloth!", so I'm sorry but I'll have to vote for keeping it . It would certainly be unique.
      So it looks like you kept the original chassis and cut out some big rectangles to fit in the new pieces? Can't wait to see your progress. Good luck!!
      It's not just an amp, it's an adventure!
        You need to be careful of ground loops. It will probably work as is....... but if it were my project I would use a steel plate if it is a steel chassis. Funny stuff happens when aluminum meets steel like that.
          Yeah, I thought about the potential for the dissimilar metals reacting, I'll probably put something in there to protect from that and make sure the grounds are solid. It's a heck of a lot easier drilling aluminum for the tube holes than steel too.
          --Jim
            Yes, I thought about making a new chassis but this is a low $ project just for me so I went the cheap & easy way.
            --Jim
              My replacement bell cover set arrived today from Heyboer (right here in Michigan) and they fit perfectly. Back to work!
              --Jim
                Well it's all together and I have no sound. None. No buzzing, no hums, nothing. Time to start looking for missed connections and voltage levels.
                --Jim
                  I am supposed to have around 415v on pin 3 of the power tubes but I have - and this seems highly unusual to me - 1100v. Is that even possible?
                  --Jim
                    Doesn't seem very probable. Try measuring across the first filter cap.
                      580v and it fell to 535v in about 30 seconds, and it's dropping 1uf about every four-five seconds now.
                      --Jim
                        Looks like it's stabilizing around 500v.
                        [edit] Oh geez, I've got 1192 on the second cap. I bet I wired one of them backwards.
                        [edit 2] No, according to an AB763 schematic they're right.
                        --Jim
                          Which AB763 is this based on? What meter are you using and do you have a good ground?
                            It's actually based on the 5F6 schematic except I used 80/80/16/16/16 for caps instead of 20/20/20/20/8. I got the voltage specs from the SR AB763 schematic but now I see the 5F6 schematic shows 425v on the first two caps where the choke connects. Yes, I checked the grounds and they all look & feel good & tight.
                            I checked with two different meters, one is a Commercial Electric and the other is a cheapie Cen-Tech, both show the same readings.
                            --Jim
                              OK, your B+ wwinding has a center tap that is grounded. Make sure you didn;t ground one of the winding end wires instead of the center tap.
