Silvertone 1464 solid state 100 amp
  • #61
    Originally posted by freegan72 View Post
    Anything else I should consider?
    This right here:
    with the exception of the expensive power supply ones.
    ANY old amp, a prime trouble spot is filter caps. Bet you half a peach swapping in new ones will diminish your hum to acceptable levels.
    • #62
      Early on I removed everything from the bridge rectifier out and used a lab DC power supply for the +26 V and -26 V. I left the filter caps in initially. I just removed them--nothing changed.
      • #63
        Thanks for the reply
        • #64
          I hope this adventure works for you and you are doing it for the learning experience.. but I wouldn’t be heartbroken if you aren’t successful. Unless something has changed these amps aren’t very valuable, functional, or even usable.
          • #65
            It's just for fun/challenge. I have no delusions that I am going to get anything out of it beyond that.
            • #66
              Other than suggesting that you start a new thread for your problem, you have already isolated the problem to the preamp (everything before Q5).
              Continue to isolate the preamp sections to try and find the problem.
              • #67
                Or swap in a bag of electrolytic caps starting with the filter caps...
                • #68
                  Conveniently, the schematic has transistor voltages. I'd start by measuring those and see if anything is off.
